Sylvania LC320SS8 32 in. LCD Television Logo
Posted on Nov 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical black lines going thru tv - Sylvania LC320SS8 32 in. LCD Television
  • protocolu898
    protocolu898 Nov 26, 2012
    Loose wire on circuit board somewhere
Level 3:
Top Expert:
  • Sylvania Master 76,851 Answers
  • Posted on Nov 26, 2012
Sylvania Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987256
Points
237762
It could be of a faulty T'Con board. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also ckick the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Black vertical lines on samsung lcd tv.when powered on the black vertical line appears in the middle
Vertical lines are usually a a sign that your T-con board is going bad. You can get replacement parts for this TV at www.interliquidparts.com
Hitachi plasma 55HDS69 had lines going thru it then heard sizzle sound and went black.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem and do take care....
I have a black line on the tv samsung
Hope this help......
Tv runs fine for 30-45 minutes then goes black except for bright horizontal line thru center of screen, volume stays on
This is a vertical problem. It may have a bad solder joint or it has a vertical IC or surrounding compoenents heating up and going bad, Try not to have the horizonal line on for to long, it can burn the screen if left on very long. If you have some electronic experience you could get some freeze spray and wait for the set to mess up and spray the freeze around the vertical section and locate the part that is heating up. Be careful because there is HIGH VOLTAGE is this area. Hope this is helpful.
3 Black vertical lines on my Gateway Plasma TV
i just fixed my gateway 42"plasma with the exact problem.  go to this link, and read entirely and follow!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Black screen with colorful line going horizontally through the middle of the screen
Problem in the vertical circuitry.
If you have the know-how, check for "cold-solder" joints around vertical i.c.
Also, bad electrolytic caps.
Voltages ok?
Resistor values ok?
Replace I.C.
Don't tell me the yoke wires were off or gnawed thru by a roach!
1helpful
4answers
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
5helpful
Line going thru the tv
Josh, When you say a line going through your TV is it a line from left to right or top to bottom? Is there a picture present and this is a line imposed on the picture or just a line by itself? Let me guess, you have no picture just a horizontal line (from left to right) across the middle of the screen. If so that is collapse of the vertical deflection and most likely caused by failure of the vertical IC and possibly linked to some bad caps in theat circuit as well. It's not an expensive repair, just find a good reputable shop. You might also mention, or if they ask, that your unit is a lighbox. Meaning that when they go to repair it the insides of the unit separate from the cabinet for easier access.. Good Luck Bill
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
