SOURCE: my singer athena 2000 won't
Yes, the hook timing is off. You need to either take it to a service repair center, or do the timing yourself. If you're mechanically inclined, go to youtube and look for a video by Nilsandkatrina about how to repair your sewing machine. He gives a very good example.
SOURCE: can't get the bobbin thread to raise
i have a singer inspiration my needle is hitting the bobbin case and needle keeps on breaking not picking up the thread . how can i fix the bobbin case. help
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
SOURCE: Singer 5817C bobbin pulls out of casing
This will happen if the bobbin is put in the wrong way around - I believe the thread should be going in a clockwise direction as you face it. (If this is the way you have it, try the other way!)
SOURCE: thread from the needle wraps around the bobbin case and knots
hi! there,
wrong set up made this thing goes wrong,well
its good things to go to internet, on address
type www.youtube.com type on search
box type "sewing macnine" there some
instruction follow specielly set thread and
bobbins and some otrhe sewing feature that
you can learn.have a nice day dont forget to
rate me, thank's
Thanks Debi - now sorted!
