Question about Emerson Black Microwave Oven
How do you set the clock for the Emerson MW8999SB microwave?
After setting the clock, the colon continues to blink. Is this normal?
SOURCE:
MicrowaveSvc
  • 9173 Answers
SOURCE: setting the clock on Emerson MW 8115SS
Press Clock, press the numbers for hours & minutes, select with AM/PM pad, then press Clock again to set it.
Yours Emerson microwave owner's manual is available for free download here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 11, 2008
MicrowaveSvc
  • 9173 Answers
SOURCE: trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Posted on Jul 18, 2008
MicrowaveSvc
  • 9173 Answers
SOURCE: setting clock
Your owner's manual is here.
Posted on Mar 02, 2009
localwonder
  • 6784 Answers
SOURCE: i have an emerson microwave model# mwg9111sl that
Yes, this is a major issue concerning the control board(control fault). replacing the control will fix this issue.
Posted on Jun 22, 2009
rhozel2010
  • 269 Answers
SOURCE: Emerson MW9111 will not heat- all timers & clock work
Hi! try checking the fuse that goes to the magnetron.
Posted on Sep 12, 2009
How to set the clock Model NN-SA651S
To set the clock, press Timer/Clock twice when the microwave is not in use. The colon between the hour and minutes should start to blink. Type the current time (12-hour clock) with the appropriate number key pads. To save the time and exit the clock set mode, press Timer/Clock once more. Note: if you take too long to begin typing the time, the microwave may exit the time set mode. In that case, the colon will stop blinking. None of the other features of the microwave will work when the colon is blinking.
This is shown on page 11 of the manual which is available on the Panasonic NN-SA651S support page: http://shop.panasonic.com/support-only/NN-SA651S.html . The direct link to the manual is currently ftp://ftp.panasonic.com/microwaveoven/om/nn-sa631_nn-sa651_nn-sa661_en_om.pdf .
I hope this helps.
Mar 16, 2018 | Microwave Ovens
How to reset time
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Emerson MW8999SB 900-Watt Microwave replacement plate
From what I could find, it should be 10 1/2 inches in overall diameter.
meowpfttpftt
Mar 31, 2010 | Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
You can actually download your owner's manual here
Mar 10, 2008 | Microwave Ovens
Emerson Black Microwave Oven Logo
861 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
