Check and replace the main power supply regulator board to your TV. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Should be the fault to its main digital board. Try this link. http://electronicshelponline.blogspot.com/
There
are more than two thousand and four hundred posts. All are related to
television and other domestic electronic equipment service help.
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance. -Kirstie DISH Network
We would be happy to help you with that. Currently the onlycode we have that will allow you to control your Emprex TV is 597. If this codedoes not work we would recommend doing a power scan.
Power scan instructions:
Step 1: Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2: Press and release the Power button.
Step 3: Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4: Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer.
Phillip Chang DISH Network Customer Service Representative
You will need to program your dish remote to your tv, find the 3 digit code for your tv and on your dish remote press the TV button till all lights light up at the top of the rem, then enter the 3 digit tv code and then press pound. this will now programm that rem to your tv. be sure to press the SAT button to put back into SAT mode to operate your Dish programming.
Hi, I'm no expert but I've read alot of these posts. Also I do have that model too. Mine is totally dead, the p/s board.
Anyway get a flashlight and shine it directly on the screen with the tv on. Do you see a picture at all? Then the flourescent bulb is off. Could be the bulb, ballast or something like that. If no pic, maybe the inverter or something, now I'm just guessing.
I'll do some research for you. contact me at [email protected]
