SOURCE: want to remove wd2500 drive from HDD enclosure and
OK your hard drive is an ATA drive.
You motherboard will have two hard disk controllers, on the 1st controller the ATA cable will have two connectors - a connector will have the C drive hard disk attached to it and the jumper on the hard drive will be set as the Master drive. You may also have a CD or DVD drive connected to this cable, if so then the CD or DVD drive will be jumpered as a Slave drive.
If the second connector does not have a drive connected, then you can connect the second hard drive to this connector BUT it needs to be jumpered as a Slave drive.
You may elect to connect the second hard drive to the second IDE controller instead on the first controller. If there aren't any drives on the second ATA cable then the second hard drive can be jumpered as either a Master or Slave drive.
If there is a drive on the second ATA cable you need to determine the jumper setting of that drive and then set the jumper on the second hard drive to a different setting. BOTH drives on the same cable CANNOT have the same drive setting.
After installing the second hard drive, check the BIOS configuration of the second hard drive, if the hard drive is detected then when Windows boots up you will see the hard drive and its contents.
AU $8.40 Buy it Now + postage AU $0.96 you could get this on Ebay if you dont have an account you will need to create one https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account On Ebay summary page you will see on left a paypal link When you get to the paypal login page at the bottom you will see new to paypal sign up tab Paypal to create an account Paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress be very specific when you type in the search Always ask questions ? Before you make a purchase and keep the email /s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. or you might be able to find one closer for local pick up You would have to remove the hard drive and use a usb sata ide kit you will then have to connect it to your computer using a usb port http://www.bing.com/images/search?q=SATA+Power+Splitter&qpvt=SATA+Power+Splitter&FORM=IGRE Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually click start click on computer to open you should see this drive If you dont. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X you will need to update/reinstall drivers right click to reinstall drivers. If you can see your usb drive but its not working ports (com&lpt) right click update driver Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive or get one of these Hope this helps.
http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable
NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
Add Email adress
Add Bank Acc
Add Credit Card
If you dont.
or get one of these
Hope this helps.
