Mine is also stuck. The ring to pull it out even broke. It looks like there is some sand around the edges. Tried to push them down with a knife, but don't want to break anything.
You can't post conmments that contain an email address.
Usually the battery in this unit will last about four years however if
you register your details with a valid email all BRITA products will
come with a 2 year manufacture guarantee... but should any part of it
break, we will send you a replacement part absolutely FREE
Don't
bother trying to replace the CR1616 battery yourself it is a
sealed unit and once the seal is broken you can replace the battery but
it will fail very soon with steam ingress even if you superglue it.!!
It sounds like the adapter was screwed in at an angle. This causes the threads to cross in turn making it near impossible to unscrew. Since it is plastic I recommend buying a new adapter. I know it's unfortunate, however it is a lost cause.
From the description of this model's replacement filters, they appear to be carbon filters. What you are seeing is most likely bits of carbon granules from the filter media (which doesn't say much for the construction quality of these filters). I would suggest getting an inexpensive countertop or under-counter filtration system instead of using Brita pitcher filters. These systems usually come with both carbon and sediment filters and if you get a non-proprietary one (i.e. not a system off the shelf at Lowe's), the filter elements are a lot cheaper to replace.
Want a free adapter and patient enough to wait for a couple of weeks to get them?
"To receive a special adapter free of charge, call 1-800-24-BRITA or 1-800-387-6940 (CANADA)."
Call the number above and a voice prompt will give you instructions on how to get your adapter for free. 2 weeks might be too long but the best thing is it is made of stainless steel/chrome and it comes in 3 different kind of adapters with rubber washers.
You can order from amazon. Usually ship in 1 day. I'm very satisfied.
But, Brita filters are not the only filters on the market. There are better Brita alternative filters.
