Question about Leviton Electrical Supplies
Lights do not come on only little green light blinks
3 Suggested Answers
SOURCE:
  • 11 Answers
SOURCE: blinking green light/won't detect disk drive
the sata cable sliped from the dvd drive (if under warranty send it back) if not open yourself and plug it back it
Posted on May 24, 2009
Slinteriors
  • 8617 Answers
SOURCE: i have a ws-55859. All of a sudden the tv stopped
the DM capacitors need to be replaced. Very common problem You can get the correct repair kit at the following link for your model which contains the capacitors and the instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Jun 19, 2009
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
Green light blinks then stop stay green
Most of these sets the green light will if the set is unplugged and plugged back blink for 70 seconds and then go out. Set should be able then to be turned on.
What is model number and a little more about what is happening?
Apr 30, 2012 | Mitsubishi Televison & Video
Canon ip1800 green light blinks once and orange light blinks three times
try to clean the circuit of the cartidge with dry tissue or cotton cloth with little alcohol if blinking again replace new one black or color catridge
Jan 27, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Optiplex light blinks, fan goes for a second but won't turn on
you may want to do a search on the dell website, i had that problem and never fixed it, you might find the information under service manuals search.
good luck.
Aug 11, 2009 | Dell Optiplex GX270
Blinking green light/won't detect disk drive
May 22, 2009 | Microsoft Xbox 360 Pro System Console
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
Constant green blinking light Mitsubishi tv WS-65513
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi HD TV 1080 blinking green light
sounds like it has a bad DM assy, or a bad 9v reg ic.
the dm can be repaired, there are 4 capacitors on it that need to be replaced.
Dec 13, 2007 | Televison & Video
Electrical Supplies Logo
83 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
