I have same problem, what the heck?I have same problem, what the heck?
AnonymousMay 15, 2009
the book says 'system busy' on the handset means the maximum number of handsets are in use. which is bogus because it's supposed to take eight and now its balking at taking a third. i'm also getting an icon 'r' in the upper lefthand corner which means 'handset not yet registered, or searching for base.' i actually replaced the base unit because the original one started doing this after three years. the book says 'system busy' on the handset means the maximum number of handsets are in use. which is bogus because it's supposed to take eight and now its balking at taking a third. i'm also getting an icon 'r' in the upper lefthand corner which means 'handset not yet registered, or searching for base.' i actually replaced the base unit because the original one started doing this after three years.
I have the same issue, I dont see a resoltion posted. Did anyone get one emailed to them?I have the same issue, I dont see a resoltion posted. Did anyone get one emailed to them?
AnonymousMar 29, 2014
asterisk appear in displayasterisk appear in display
You can't post conmments that contain an email address.
To register a handset to your telephone base Make sure the handset battery is installed and charged properly. You have to enter a 15-digit telephone base ID to register the handset to the telephone base.
To find the telephone base ID and register the handset:
1. On the telephone base, press the MENU softkey when in idle mode to enter the feature menu. Press the or softkey to scroll to the DISPLAY BASE-ID menu, then press the OK softkey. The telephone base ID will be displayed.
2. On the handset, use the keypad buttons to enter the telephone base ID and press the OK softkey. Press the softkey to move the cursor.
3. The handset will first display PLEASE WAIT!!, then T23 PD followed by SEARCHING FOR BASE. The screen will finally display HANDSET X when the registration is successful. NOTES:
1. If the registration is not successful, the display will show NO BASE SUBSCRIPTION. Try the registration process again.
2. If an incorrect base ID is entered, the base ID will disappear and ENTER BASE ID will be displayed.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
From another fixya post: 1. Make sure to charge the handset battery pack at least 12 hours. 2. Using the soft keys on the base located below the base screen, press MENU. 3. Use the up or down arrow keys to select DISPLAY BASE ID. 4. Press OK. The base screen will display the 15-digit Base ID code for about 30 seconds, then the unit returns to the idle screen. Write down the Base ID code on a piece of paper. 5. At the cordless handset, use the soft key to select NEW. 6. Enter the 15-digit Base ID code using the number keypad. 7. Use the soft key to select OK. The screen displays PLEASE WAIT!. 8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in use.
please follow the instruction to register the handset to base
To register a DCX150 accessory handset: 1. Charge the handset completely. 2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD. 3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number. If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely. 2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink. 3.On the handset, press and hold # until the handset beeps and displays Handset Registering. 4.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
When you pick up your GE cordless phone and press a button, the phone
should beep as a confirmation that a button has been pressed. If the
telephone handset does not beep, or if it does not respond to any
buttons, the battery may be in need of a recharge. Verify that the
cordless phone base unit is plugged in to an electrical source, then
place the handset into the charging cradle. If no lights illuminate on
the phone, or if charging fails to correct the issue, clean the metal
charging contacts on the cordless handset and place the phone back on
the charger. If it still fails to respond or to charge, the unit may
need to be serviced or replaced.
Does the Battery Hold a Charge?
If the cordless phone charges up and appears to be ready for use but
dies after only short periods of use, the internal rechargeable
batteries may need to be replaced. Replacement batteries are widely
available at electronics
and discount retail stores. Note your phone's exact model number, as
this number will be necessary when purchasing a replacement battery.
Listen for a Dial Tone
If the GE cordless phone powers on, and beeps when you press keys, but
no dial tone is heard, one of three problems is the likely culprit. The
phone's batteries may have an insufficient charge to fully power the
phone, a condition that can be corrected by simply placing the phone
back in the charger. If the batteries are charged, but no dial tone is
heard, it is also possible that another telephone in your home or
office is "off hook" or in use; verify that all telephones, fax
machines and modems are securely on the hook. If there is still no dial
tone, your telephone service may have been disconnected or require
service by your local telephone company.
Listen for Static
On some GE cordless phone models, particularly older models, static may
be heard if the radio signal between the handset and base unit
experiences interference. Common sources of interference include
unshielded electronics, appliances, and radio transmitters, as well as
high-tension power lines. If your phone offers an option to change
channels, try several different channels to see if the static is
eliminated. If static continues to exist, or if static can be heard on
wired phones sharing the same line, your telephone line may require service.
Verify Your Handset is Registered
Some models of GE cordless phones may display a message on the display
screen that the handset needs to be registered. If this message
appears, move the handset close to the base unit and press the
"Prog/Mute" button near the bottom of the handset. Next, press the
"Pager" button on the base unit (your handset may instruct you to
perform this step). Finally, press the "Prog/Mute" button on the
handset one more time to complete the registration process. Your GE
cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of
cordless home service with quality sound and features. There are many
models of the GE Cordless Phone. The most current models, including the
DECT 6.0, have standard features such as call waiting, caller ID,
visual ring indicator, phone number memory and digital answering systems .
Before
you use your GE Cordless Phone, ensure that you have all the parts.
Your cordless phone package should include the phone base, a handset
battery pack, a battery compartment cover, the cordless handset, a wall
mount bracket, and a telephone line cord and AC power adaptor. Once you
have confirmed that you have all of your parts, insert the handset
battery pack into the handset and replace the battery compartment
cover. Insert your telephone line cord and the AC power adapter into
the phone base. The phone base identifies the telephone line as TEL
LINE and the adapter as AC. Plug the phone base into the electrical
socket. Place the cordless handset into the base. Allow the phone to
charge for at least 16 hours before its first use. Failure to fully
charge the battery before its first use will result in poor battery
performance.
Once you have fully charged your phone, you can proceed with setting up
your phone's features. If your cordless phone includes an answering
system, complete this setup process first. Turn on the answering system
by pressing the on/off button. The message indicator light will
display. The cordless phones
are defaulted to English as the selected language. To change your
language preference, press the "Skip" button for two seconds. The
language will change to Spanish. Next, you will set up your voice time
and day stamp. While the answering system is on, press the "Answer"
button on your handset for two seconds. The phone will enter the
answerer mode. Press the "8" key. This will take you to the time/day
setup menu. Use the number keys to set the hour and minutes. Use the
volume up and down arrows to set the AM/PM. Press "#" to save. The
cordless handset will also require that you give it a name. Press the
"Mute" button for two seconds until the handset reads "ENTER NAME."
Enter the name of the handset by using the touchtone keypad. Press the
"Mute" button to save. Enter the default area code by pressing "Mute"
until the phone displays "AREA CODE." Enter your three-digit area code
and press the "Mute" button to save.
GE Cordless Phones are designed to be simple and convenient to use. To
place or answer a call, press the TALK button. You can pre-dial a
number by dialing the number before pressing the TALK button. When you
are ready to make the call, press TALK and the phone will dial
automatically. To answer a call that is waiting on the other line,
press the FLASH button. If you experience call interference or bad
reception while on a call, press the CHANNEL button until your line
clears
brand is designed to deliver the conveniences of cordless home service
with quality sound and features. There are many models of the GE
Cordless Phone. The most current models, including the DECT 6.0, have
standard features such as call waiting, caller ID, visual ring
indicator, phone number memory and digital answering systems.
Before You Start
Before you use your GE Cordless Phone, ensure that you have all the
parts. Your cordless phone package should include the phone base, a
handset battery pack, a battery compartment cover, the cordless
handset, a wall mount bracket, and a telephone line cord and AC power
adaptor. Once you have confirmed that you have all of your parts,
insert the handset battery pack into the handset and replace the
battery compartment cover. Insert your telephone line cord and the AC
power adapter into the phone base. The phone base identifies the
telephone line as TEL LINE and the adapter as AC. Plug the phone base
into the electrical socket. Place the cordless handset into the base.
Allow the phone to charge for at least 16 hours before its first use.
Failure to fully charge the battery before its first use will result in
poor battery performance.
Phone Setup
The Basics
clears.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
First thing you must do, is clear the base memory of the phones.
To deregister all handsets:
Select MENU on the base, scroll to SETUP BASE,
then select OK.
Scroll to DEREGISTER ALL and then select SET. Thebase will display DO YOU WANT TO DEREGISTER ALL HANDSETS?
Select YES. All handsets are deregistered and are unusable until each has been re-registered
During registration,you must enter the 15-digit ID number of the telephone base. To find this number, go to the base, select MENU, scroll down to DISPLAY BASE ID, then select OK
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Cannot register handset with base, gives error message T23 PD. Subsequently says "SYSTEM BUSY!"
I have the same problem on the same phone - did you get it resolved?
