When I plug my iphone into my laptop, itunes pops up but displays message stating... "iTunes could not connect to the iPhone "Cody's iPhone" because an invalid response was received from the device."
After updating OS, you may receive "iTunes could not connect to the iPhone because an invalid response was received from your device".
iTunes Could Not Connect to the iPhone iOS 10 iTunes Invalid Response...
Here are the best four methods for you to refer to fixing this iTunes could not connect to the iPhone invalid response problem, via updating iTunes and iPhone, uninstalling and reinstalling iTunes, and using iPhone alternative.
SOURCE: Error while syncing my iPhone to itunes-phone won't turn on now
in order to fix your phone, you`ll have to force it to DFU mode and then iTunes should be able to detect it. Once detected, it would ask you to update it to latest firmware. Afta the update your phone would work just fine.
To get it to DFU, follow these steps.
1.Connect your phone to PC.
2. Turn it off completely. To turn it off, press and hold the power button untill you get the the option, slide to turn off.
3. Then, press and hold the power button for 3 seconds.
4. Without leaving the power button, now press and hold the HOME button, for 10seconds.
5. Now leave the power button, but keep holding the home button for next 20 seconds.
The phone should be detected by the PC to be in recovery mode. Now, iTunes will help you update and/or restore your phone.
SOURCE: Iphone "There is not enough memory available"
There needs to be sufficient disk memory on the PC to hold the contents of the iPhone (8GB or 4GB) plus some extra. This is because the iTunes backs-up the iPhone before the restore. Check and clear some space on your PC hard drive and try again.
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
SOURCE: iphone disabled connect to itunes
Here are your instructions from the website below.
Reset your iPhone Passcode:
If you have forgotten your iPhone's Passcode you will need to restore your phone via iTunes.
But first you have to put your phone into the restore mode which is a slightly fiddly process.
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode. You should then follow the steps above to activate the Passcode with a memorable number
http://www.knowyourmobile.com/appleiphone/apple_iphone_userguides/4684/how_to_password_protect_your_iphone.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Iphone, not reading sim, not connecting of itunes...
another way to restore it would be to turn the device off, then hold down the power button and plug it into your cpu still holding the home button and it should show up in itunes
I had a similar error while I was using an iPhone 8, I fixed the issue after updating my iOS. anyone interested can feel free to visit :https://babasupport.org/apple/fix-itunes...
