Went i connect my laptop to my tv i have good picture in my tv but in my 15.5 " screen is black i can see the pictures but is no light how can i fix that
If you can see a "ghost Image"on the laptop monitor in a bright light, the backlighting isn't on, the backlighting is switched on/off by a tiny switch near the hinges of a lartop. Sometimes will stick closed due to damage, dirt, dust, loose hinge ,etc. Also, due to a drop, bump, jar, etc. the ribbon cable on the back of the monitor may be loose. OR the wire is damaged/pinched the supplies power to the backlighting. OR the CCL/LED/ whatever backlighting your laptop has is out.
no max doesn't work thanks for your help i check everything and no stay the same .the laptop work 100% the only thing is no light in the screen i connect the laptop to the tv and get good picture wenth i clouse the laptop the picture go away so thats meens is working i sospect is the lcd light power suplice
Yes, The light or a ribbon cable, pinched wire. Seems the switch is functioning if the external monitor is responding to the laptop lid closing.
You have verified the driver is installed and correct.
