You have to be the computers administrator to change any values on any hard drive on your computer. Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP Click start right click on my computer select open Click start click on my computer you should see your usb drive right click then select format another way is to control panel administrative tools computer management disk management right click on your drive select format
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
If you need more help with this post a reply
Hope this helps.
Turn your computer on and plug the external hard drive into the computer.
Open "Computer Management" by clicking "Start," "Control Panel," "System and Security," "Administrative Tools" and "Computer Management."
Click "Disk Management" in the left pane under "Storage."
Locate your external drive from the list of hard drives connected or installed on your computer.
Right-click the drive and select "Format."
Select a file format from the drop-down menu. Choose "NTFS" if you will be using the external hard drive with a computer that uses Windows 7, Windows Vista or Windows XP.
If you will be using the hard drive with an older version of Windows, select "FAT32."
This is a much less common format.
Click "OK" twice and your external drive is formatted. Once the drive is formatted, it is properly set up to be used with your computer.
hope this helps
