SOURCE: Kodak EasyShare M340 Digital Camera
Maybe, the batteries need to be changed to new ones.
Try to use Li ion batteries as recommended by Kodak.
SOURCE: Black screen Kodak EasyShare C653 Digital Camera
probably you unable the lcd display function, try hit |0|i button, its upper menu in you camera, also you could try hitting menu button, if lcd comes back and you can see menu, then is not a camera problem, it's a configuration. i recomend you read quick starting guide.
gretts, a.
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
SOURCE: Kodak easyshare M893 IS will not stay on. The
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: Hi... I have a Kodak EasyShare CD82 Digital
Sherry, have you tried to replace the battery of your camera? The recommended battery for your camera are the Ni-MH battery and the Alkaline battery. Now if you already using this type of battery and still your LCD screen is black its time for you to call Kodak at 1 800 235 6325 ext 12, it means that the LCD screen of the camera is already defective.
