Push the eject button on the drive. OR open MY COMPUTER, right click on DVD/CD rom drive, eject. If all else fails, remove drive open case remove disk, inspect for debris in drive.
Press the eject button on the top right-hand of the keyboard. Be patient if the disc does not pop out immediately. Try pressing the button a few times or waiting a few seconds and then press the button again. If it doesn't eject, tilt the computer with the disc drive facing down and shake it gently as you press eject.[1]
2 Drag the disc icon into the trash. If the eject button isn't working, locate the disc icon on your computer's Desktop and drag it to the trash can. The trash can is located on the far right end of the Application Dock on the bottom of the computer screen.
3 Press and hold "Command" while simultaneously pressing "E."
4 Find the disc in the Finder. Open the Finder, located on the bottom left of the applications dock. Look on the left-hand side of the pop-up window under "Devices" for the name of the disc in your drive. Locate the eject button directly to the right of the disc name and click on it.
5 Eject the disc through an application if it is not in the Finder. In iTunes or DVD Player, click on the "Controls" drop-down menu located on the top toolbar and click "Eject Disc." You can also open iTunes and click on "Playlists" so that the left side bar pops up. Look for the CD icon with the appropriate name. Click the eject button directly to the left of the CD name.
- normally discs will be ejected if you press the eject-button on the top right corner on the keyboard.
sometimes a restart with a pressed down eject-button is needed to get the disc out. Understanding Mac Keyboard
I had the same problem. Take the top off and wind the loading wheel until the mechanism engages and loads - but with no disc in place. Then unplug the power and look through the top. You will see the lens. Clean with rubbing alcohol and a q tipi and dry with a clean q tip. Try playing a disc
Try to eject a disc using the eject icon in the "Devices" section of your Mac "Sidebar" or using the eject key on your Mac keyboard. If the disc refuses to unmount and eject, move on to Step 2.
Navigate in an open Finder window to "Applications/Utilities" and double-click "Disc Utilities" to launch the application
In the list of available discs, on the left-hand side of the "Disc Utilities" application window, select the mounted CD or DVD with a single-click.
On the top of the "Disc Utilities" window, single-click the "Unmount" button. Your disc will unmount and be ejected.
Please let me know if you have any further questions or concerns.
Thanks.
Some of the iomega hard drives don't communicate with Windows XP very well. Ejecting isn't needed, but you simply unplug it. Just make sure you are not accessing it at that time. You can also shutdown the computer and unplug it then. Restarting the computer may also allow you to eject it.
Hope this helps!
Rate my solution!
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
