Question about Hardware & Accessories
Electric motor make, lamco, model no.EC34-1(93) reversing 120v 16.5amps
I need info on how to re-wire this electric motor to a manual rotary switch. not for a tv not for a car but a electric motor. moteur electric. I have colour codes connected to a board, connections w1, w2, v1, v2, u1, u2. lamco electric motor model no#C34-1(93) reversing electric motor 120v, 16.5amp. this is not a cat, a tv or a car but a electric motor
    New Friend:
Very informative article especially for me as an Eng.
www.mrosupply.com
Posted on Jul 14, 2013
    New Friend:
Have you found the solution yet, if so could you show ? . i have the same problem thanks
Posted on Dec 10, 2012
  • Gene Haynes Dec 10, 2012
    Post your image or solution on this link.
    Oops Mike. I thot you said you HAD solution: Here are some extensive motor resources:http://waterheatertimer.org/Color-codewi...
  • 5,353 Answers
Here are electric motor links that might help.
Or not.
http://waterheatertimer.org/Color-codewire.html#motor
You have to test the windings with multimeter to identify start winding, vrs run winding.
Both windings receive power at same time.
The start winding is like first gear on a car. It starts the motor rotation.
The run winding brings motor up to rated speed.
Sometimes categories at Fixya are muddied, and people do not say which product they have, or give UL number instead of product number, and sometimes fixya questions are truncated onscreen ... so person answering question thinks the product is a gasoline powered bobcat, instead of hybrid car, or 120Volt single-phase electric motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 27, 2012
SOURCE:
What is a comintator
According to wikipedia. a commutator is the moving part of a rotary electrical switch in certain types of electric motors and electrical generators that periodically reverses the current in a DC motor. It's part of what makes the motor run.
A commentator HOWEVER, is a person who comments or expresses an opinion on a subject.
May 14, 2014 | Electric Lawn Mower
I installed a new Intermatic timer, model # T8805P101C, it works manually but the wheel doesn't turn to automatic set timings
If the dial does not rotate but manual override works, then the timer is wired incorrectly or polarity of line is reversed or you are connecting to 240Volt line instead of 120V.
1) You have wires from breaker box reversed with wires that goes to sprinkler solenoid. Switch black wires and see if that corrects problem.
2) Check that breaker supplying voltage is 120Volt.
3) Test if black wire from breaker tests 120V to ground wire, and test that white wire from breaker tests 0 volts to ground.
Open following links for additional troubleshoot and parts:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 04, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
We install the timer and it does not work automatically. We can switch it on only manually
You posted under T103 Intermatic 120V timer.
Sounds like you wired the timer wrong:
Timer has 120V clock motor and requires Hot from breaker on terminal 1, and Neutral from breaker on terminal A. This will power clock motor.
If you have any of the wires reversed, timer will do what you describe.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 26, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
WH40 water heater timer: Does black wire from service box go to terminal #1 and black wire to water heater to terminal #2? Does neutral (white) from service box go to terminal #3 and neutral (white) to...
WH40 is 240Volt timer.
WH40 will not work with 120V circuit.
See WH40 wiring illustration at following link:
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
There are two hot wires in 240V circuit because every circuit requires two wires to complete the circuit.
Hot wires from breaker connect to terminal 1 and 3.
Notice that small white wires are also connected to terminals 1 and 3.
Small white wires power clock motor located on back of mechanism, so this says power from breaker box must arrive on terminals 1 and 3. This insures that clock motor runs continuously.
If clock motor only runs when manual override switch is clicked ON, then your Hot and Load wires are reversed.
Bare ground wire connects to green ground screw.
Wires going to Load (water heater) connect to terminals 2 and 4.
FYI: Terminal A is not used unless circuit also has a Neutral wire,
See basic water heater circuit Diagram #2:
http://waterheatertimer.org/240-v-water-heater-circuit.html
Terminal A is also used if you want to convert WH40 to 120V timer by replacing 240V clock with 120V clock.
How to convert Intermatic 240V timer to 120V timer
http://www.fixya.com/support/t7353947-intermatic_timer_wg
Dec 24, 2010 | Electric Intermatic Inc Wh40 Water Heater...
Looking for lubrication info on Bosch rotary and demolition hammers. I am doing a service pack and need to know proper lubrication points and amounts to refresh my drills for work. Any place to find repair...
try going to Boschtools.com and you will need your exact model number but they have parts explosions with the grease points listed on most of them Let me know if you need more assistance.
Mar 06, 2010 | Rotary Bosch 11263evs 1-3/4'' Sds-max® ...
How to wire this ge timer 120v
Open following links for GE timers and 15087 wiring:
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
GE box timers can be wired many different ways to control single-loads, multiple loads, 2-speed motors, 120V, 208V, 277V, 240V, 440V, 24V.
Add a comment and say exactly what you are wiring, and what voltage you are using for more information.
Dec 07, 2009 | General Electric GE 56941 24-Hour Outdoor...
Hilti TE 17 Rotary Hammer repair switch fix The wirei loose how to reatach to motor?
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Oct 29, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti Hammer Drill 76p atc wont spin, has flashing led
Sounds like it needs new brushes. Schematics can be found on hilti.com. tech support - rotary hammers/ combi. Look up model number. Some of the older stuff is obsolete. Should find info there.Please rate me
Apr 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Window Fan switch bad
Steve, Your fan model is HV-18-WR; I have 2 with the same problem. I can't find a source for DYE-3606 switches either. Here is one source for rotary switches; one might be suitable: http://www.alliedelec.com/Catalog/Indices/Products.asp?sid=46BBAA8076DBE17F&N=4294828748 I can draw a diagram of how the existing switch is connected, but I don't know how that would translate to a replacement switch.
May 22, 2007 | Lakewood HV12WR Window Mount Fan
Hardware & Accessories Logo
626 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
