Panasonic VIERA TX-32LXD80 32 in. HD-Ready LCD TV Logo
Posted on Nov 25, 2012
Help no sound panasonic tx 32lxd80 - Panasonic VIERA TX-32LXD80 32 in. HD-Ready LCD TV
1helpful
How do I connect it to the internet to get updates?
you will have to hard wire to internet modem or go wireless option.
2helpful
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Where can i get a replacement users operating manual Thank you
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
I have a Panasonic Viera TV which I have connected to my Talktalk broadband router by a Lan cable. I can connect to BBC iplayer ok but have been unable to set up the netwok services as I am required to...
If you are using a direct Cat5/6 cable connection between the unit and the modem, you should not have to enter any codes as this is a direct communication from one device to the other. If you were using Wi-Fi Wireless, ye; then you need codes to authenticate the connection.
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Stand on t.v wont *** off
There are six screws at the back, at the bottom, three on each side. Undo them and the base pulls out. Beware, it's very heavy.
No problem - IF you do ALL 6 of them !
1helpful
2answers
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
5helpful
2answers
Panasonic TX-34P300X Audio problem
I have facing some problem model Tx-34P300X panasonic Tv UK Model for sound not coming .But Amplifire is Ok. Pre not working.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
