SOURCE: I have a Dell Inspiron 1520 laptop. Fan has gone
that is absolutely right i work for the same and we charge $49 If you bought the sys. after sept. 2004. and you are out of warranty.***let me know what is the blue screen all about.and stop erros code with 0x000000** this blue screen will help us to understand the issue. and i can help you to resolve your issue.
SOURCE: Dell Inspiron 1520 extremely dim screen
You have a inverter circuit that is malfunctioning and needs replacement if it is on the mother board the mother board may need replacement . There also may be a failing video card.
SOURCE: my dell inspiron 1520 does not work at all, power
no this is not a defect this would indicate that the power supply has failed on your pc.. look at the back of the unit if the power supply light is amber in color or blinking thne there is your issue.
SOURCE: I have an dell inspiron
Do one thing, remove the battery from the laptop, connect to AC Power directly with out connecting the battery, then try to switch ON the laptop. If it got switched ON then there is problem in the Battery. If not it may be problem in the Power button or in the Mother Board.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
