Check where did you hooked dvd players video-audio leads / wires in TV. Read that input number and set same input by remote in TV to see dvd picture.Check where did you hooked dvd players video-audio leads / wires in TV. Read that input number and set same input by remote in TV to see dvd picture.
You can't post conmments that contain an email address.
Re: how do i connect a dvd player to soyo atlas dylt3212...
You have to use the remote and hit the input button , look at the back of the tv where you plugged the cables in, it will tell you what input it is plugged into, chang your input to that one on the tv- using the input button
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
You need to get an RF modulator if you want to connect to the antenna
input on the back of the TV set. You can use the composite output of
the Memorex - the yellow cable output - and connect to the video input
on the front of the TV, and use the red or white output from the DVD to
connect to the audio input on the front of the TV. You will have to
press the 'game' button on the remote to select the front audio/video
inputs.
tom
If you are plugging your DVD Power Plug into the TWC Box. Unplug it and plug it into a 'known' hot socket, (wall..con strip.etc.). Ensure the AC plug is inserted fully into the DVD player. The TWC AC connection may be disabled.
The Directv box should have at least two sets of out puts. You did not
say what receiver you have and if the dvd is a player only of a
recorder so its hard to say how to connect it.
If you have a dvd player only then take the output from the dvd player
and connect it to you tv's second input, HDMI or component or what ever
is a match between the two unites.
If you have a DVD-Recorder that you want to record programs from the
directv receiver then take the second output from the receiver and
connect it to the input on the DVD-Recorder and connect the output as
above.
