My washer won't turn on when I press the START/ON button. When I unplug and plug it back in, all the lights blink a couple times, but nothing happens when I press the on button.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
SOURCE: The Crosley washer stopped running
I do not have the decode for Lr either so sorry, absolutely no promises but it's worth carrying this out anyway! (Could be a motor problem).
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: I have a crosley washing
Absolutely! There is probably a blockage either in the drain filter and/or the drain motor/pump.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
John C
Addressing Power-up/Start-up Issues:
E. Some models require you press down on the Start button until the unit powers up.
F. Some models require you press down on the Select button until the unit powers up.
G. Some models require you press the Select button first before pressing the Start button.
In the end, were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Have the breadmaker serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the breadmaker's electronics by pressing down on the Stop button until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press down on the Start button instead. And yet a few others require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. r53w6t
