I buy the chainsaw last week and I don't know how the oiler systeme work. Help me!!!
SOURCE: Poulan P3314 Automatic Oiler
Go to Poulanpro.com and look at a parts explosion and they also have a toll free number that might help. let me know if not and I will research more.
SOURCE: Need the know the correct H and L settings for our
There are no hard and fast settings.
The initial starting point "H" and "L" are 1.5 turns CCW from lightly seated.
The"T" adjustment enters here too (idle speed) and there is initial setting without a tach, depending on age may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Fresh mix of fuel. Put ALL of the old mix in any 4 cycle and start new. I suggest 50:1 regardless of what your manual says. This is the best performance adjustment I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
