Question about Samsung LN46A550 LCD TV
Problems with the picture mode on my samsung 46''
My new samsung tv has 3 picture modes; dynamic, standard, and movie. If I set the picture mode to standard within about 30 minutes the tv switches the picture mode to dynamic automatically. It also switches the picture size to 16:9 no matter what I have it set at i.e. wide screen. I can't figure out why it keep reverting back to these settings. Any ideas?????
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Posted on Jan 22, 2009
  • 3 more comments
  • snap_and_pop Jan 29, 2011
    i used what you said ...but the tv wont let me choose plug and play mode, its greyed out
  • richdavis53
    richdavis53 Feb 29, 2012
    The reason it won't let you choose "plug and play" mode is because you need to make sure your "source" is "TV" - if its "HDM1" or something other than "TV" it will be grey. Once you choose "TV" as the source, then "plug and play" with be white and you can choose it. I had the same problem on my tv, but its fixed now. It was stuck in "demo-store" mode and I changed it to "home" mode. Good Luck.
  • querra_q
    querra_q Jan 31, 2013
    Great tip !! Problem solved!
  • Sinan ENBA
    Sinan ENBA Aug 24, 2014
    yes thnx all
  • david hogan
    david hogan Mar 27, 2019
    plug and play option is grayed out.
  • 133 Answers
Go into the menue, go to picture or video, go to aspect, make sure it isnt on auto, if it isnt, and it keeps changing, you will need to call samsung, you have a problem with the main board, it can cause everything your discribing
Posted on Jan 10, 2009
SOURCE:
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Samsung LCD TV LE40R8 - Hard Reset
How do I reset the picture on my LCD TV to the factory settings?
The P.Mode button on the remote of your LCD TV lets you cycle through four factory preset picture modes: Dynamic, Standard, Movie, and Custom. To return the picture on your TV to the original factory preset, press the P.Mode button on your remote until the TV displays the Standard mode.
Nov 14, 2007 | Televison & Video
I change the color setting in my tv by accident and now i dont get green or red to show it shows brown how do i correct the setting
hello there,
Your TV has three automatic picture settings ("Dynamic", "Standard", "Movie") that are
You can activate a Picture Setting by making a selection from the menu.
1 Press the MENU button to display the menu.
Press the ENTER button to select Picture.
2 Press the ENTER button to select Mode.
Press the ? or ? button to select the Dynamic, Standard, or Movie picture setting, then
? Choose Dynamic for viewing the TV during the day or when there is bright light in the
room.
? Choose Standard for general TV watching mode.
? Choose Movie when watching movies.
Press the P.MODE button on the remote control to select one of the standard picture
settings.
3 Press the ? or ? button to select Contrast, Brightness, Sharpness, Color, or Tint,
4 Press the ? or ? button to decrease or increase the value of a particular item.
? You cannot adjust the Tint in DTV, Component or HDMI mode.
5 Press the ENTER button to return to Mode.
6 Press the ? or ? button to select Color Tone, then press the ENTER button.
7 Press the ? or ? button to select Cool2, Cool1, Normal, Warm1, or Warm2, then press
the ENTER button.
? When the picture mode is set to Dynamic or Standard, Warm1 and Warm2 cannot be
selected.
8 Press the ? or ? button to select Reset, then press the ENTER button.
? Each picture mode can be reset.
there ya go if you need anymore help let me know and don't forget to Rate
Jan 26, 2011 | Samsung TX-T3093WH TV
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Jun 09, 2010 | Sharp AQUOS LC-52XS1U-S LCD TV
HLT6176SX/XAA TV ''MAKING DETAILED SETTINGS FOR PICTURE''
Your TV is on display mode!! The problems that you are having I had with my new TV.. Call Samsung or go online to their website and it will tell you exactly how to fix that small problem. As for the blue light, just go to setup and under light effect you will be able to choose when you want the light to come on.. I hope this is helpful...
Apr 07, 2009 | Samsung HLT6176S Television
SHARP LC-32SB24U. AV MODE KEEPS GOING BACK TO DYNAMIC FIXED .
I have the same tv and i just fixed it! mine was a display model at wal mart so it was set to reset to Dynamix (fixed) after 30 minutes of no remote activity
THE FIX: switch to TV MODE and select the EZ SETUP from the option menu
when you get to the TV LOCATION option select HOME
The STORE option resets the TV after 30 mins of remote control inactivity in case someone messes up the picture settings in case someone playing with it while it was on display at the store
Jan 18, 2009 | Televison & Video
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Poor picture
Dynamic mode will give you a brighter picture. The energy saving mode runs the lamp at a more efficient level that saves energy at the cost of a slightly darker picture. Based upon your description, I'd guess that the lamp is nearing the end of its useful life. Plan on changing the lamp soon. When you do so, place the set back to standard mode and energy saving.
Dan
May 30, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
SamsungLE26 R8 Picture Settings Problems
tv had reverted in to shop mode.I accessed the secret bmenu and restored the normal settings. Thanks
Apr 07, 2008 | Samsung Televison & Video
Samsung LN46A550 LCD TV Logo
3,681 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
