Childesigns Shelby Crib Logo
Mary Dandridge Posted on Jun 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Crib sturdyness I have a crib that I got used from someone that had it for only one child. After assembly, it seemed to rock back and forth like it wasn't all that sturdy. It still works however, but I was wondering if I was missing anything during assembly that would cause it to do this. The mattress spring frame sits on some brackets that are screwed into the ends. The crib front bars go up and down within their slots like they're supposed to. So what's up? Does anyone else have this problem? Thanks in advance..
Linda Holliday Knox
Level 1:
  • Contributor 5 Answers
  • Posted on Apr 07, 2008
Linda Holliday Knox
Contributor
Level 1:
Answers
5
Questions
Helped
1933
Points
9
Alot of times cribs that have spindles all the way around or slats have a tendency to loosen around each slat. (probably caused by not keeping the crib screws tightened enough) that or a really strong baby! It seems to dance side to side. Find a really good wood glue that will seep down into each slat hole without you removing the slat and re-glue or secure every slat one by one. Flip the side over and do the topside the same way. Once again you have a sturdy crib. If left wobbly the potential of you cracking the wood somewhere on the ends of one side is great. If you can find it I recommend Wonderlok wood glue , which is a wood glue made especially for wobbly chair legs. I had a children's resale shop for five years and ran into this problem many times. It works! Good luck to you!
Anonymous
Level 2:
Scholar:
  • Expert 48 Answers
  • Posted on Jun 05, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
48
Questions
Helped
66562
Points
107
If it feels as though it wobbles, a likely problem is that the screws have not been fully tightened. They may feel tight, but give them all one good torque turn or two, until you cant anymore, pretty much. It should solve most of the wobble.
2answers
I need assembly instructions for the Lexington baby crib model 610-250. I have all the pieces, just need instruction manual. Thank you
not sure if this is the right one, but they are all the same to a theme.
Download Assembly Instructions - Oxford Baby
oxfordbabyandkids.com > Assembly-Instructions
PDF ASSEMBLY INSTRUCTIONS for convertible crib. LEXINGTON 4 IN 1 CONVERTIBLE CRIB ... GUARDRAIL and FULL BED CONVERSION KIT sold separately.
THIS IS THE ASSEMBLY INSTRUCTIONS FOR CRIBS SOLD ...
secure.img1-fg.wfcdn.com > docresources
PDF Directions for Maintenance, Cleaning, Storage and Use of your Crib/Toddler Bed are ... Please identify the Crib'n'Double Bed by the model identification number ... also be filled with parts. I and J to prevent finger entrapment of child. I. Swing.
VIDEOS as well
https://www.google.com/search?q=Lexington+baby+crib+model+610-250&safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk03yNfyAsatM2GBiu28BBaqBugSPYQ%3A1616894023320&ei=R9hfYNuDE7OO9PwPjIe-mA4&oq=Lexington+baby+crib+model+610-250
Mar 27, 2021 • Baby Gear
2answers
Chip craft Crib assembly instructions
Request the instructions from Chip Craft.
May 22, 2019 • Baby Gear
Child craft crib model F33901.53 assembly instructions
You can locate the Child Craft crib instructions at www.child-craft.com. Assembly instructions are located to the right of the screen at the top. Once you are on this screen, you will need to only type in the five digit model number ( 33901).
I hope this is helpful to you.
Assembly instructions for a delta amber 4 in 1 crib
If you're looking for assembly instructions for a Delta Amber 4 in 1 crib, you can usually find them on the manufacturer's website or by contacting their customer support. It's essential to follow the instructions carefully to ensure that the crib is assembled correctly and safely.
In terms of safety, one product that you may want to consider is Hiccapop's Inflatable Bed Rails . These are easy-to-install and adjustable crib rails that can help prevent your child from falling out of the crib as they move around during sleep. They are made of high-quality materials and have been tested to ensure their safety and durability.
To install Hiccapop's Safety Crib Rails, follow these simple steps:
  1. Position the crib rail on the side of the crib where you want to install it.
  2. Adjust the length of the rail to fit snugly against the side of the crib. You can do this by pulling the rail out or pushing it in, depending on the size of your crib.
  3. Secure the rail to the crib using the provided straps. Make sure the straps are tight and secure to prevent the rail from moving or coming loose.
  4. Double-check that the rail is securely attached before placing your child in the crib.
Hiccapop's Safety Crib Rails are a great option for parents who want an extra layer of safety and security for their child's crib. They are easy to install and adjust, making them a convenient and practical choice.
Lost instructions to assemble child craft crib
Go to http://www.childcraftindustries.com click Customer Service and then click CRIB ASSEMBLY INSTRUCTIONS ...plug in your model number (11971) and it will let you download or view a PDF (Adobe) set of instructions. When you click the instructions it will ask you to OPEN or SAVE. Click save and save it to your computer. View anytime. I suggest printing a copy and keep it with the crib. Enjoy!
Jenny Linn crib instructions
We bought a used Jenny Lind crib for our daughter and when we put it together everything is tight but it's not stable. It can be rocked back and forth and we are concerned for the safety of our grandson. We need a parts list and/or instructions to see if there's anything missing.
4helpful
6answers
Need Assembly Manual for JCPenney Round Crib
Did anyone fine the solution to this problem. I don't see the solution posted.
May 04, 2009 • Baby Gear
I dont how to fix it without manual. i neeed help
To get assembly instructions go to;
http://www.childcraftindustries.com/childcraft/assistance/
and enter your crib model number. The number you gave does not look correct.
Information from Child Craft Industries
MODEL NUMBER VERIFICATION:
Crib model numbers are stamped directly on the crib in black ink on the underneath bottom edge of one of the crib sides, headboard, footboard or stamped on the label attached to the inside face of footboard bottom rail.
On other Child Craft and/or Legacy furniture the model number will be stamped in black ink on the back panel.
Often "47167" and "01700291" are mistaken for model numbers. These numbers are NOT valid model numbers.
5helpful
Putting a child craft crib together
Id need to know what model you had to put it together...
If you do know the model number just go to this link http://www.childcraftindustries.com/childcraft/assistance/
and type the model number in under "crib assembly instructions"
If you dont know the model number you might want to just browse the products and select one that looks similar to what you have and download those instructions.
Hope this helps...
1helpful
Need crib instructions for Bonnie Togs Convertable Crib
Don't use it! If it is at least 5 years old, it is too old to be safe. Second hand cribs are associated with more deaths than new ones. They are prone to more problems. Every time you take a crib apart and put it back together, you add the potential for something to break, bend, crack or get assembled wrong. Each of these problems could result in a component of the crib coming loose or detached and creating a gap or space where your child could become entrapped and be killed. It isn't worth the risk. The crib should be the safest peice of child gear you own, because it is the only place you can leave your child unattended.
Jan 05, 2009 • Baby Gear
Top Childesigns Baby Gear Experts
ZJ Limited
ZJ Limited
john h
Vinho Xie
Vinho Xie
Are you a Childesigns Baby Gear Expert? Answer questions, earn points and help others
