1995 Mercury Mystique Logo
Posted on Nov 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shifting when driving - 1995 Mercury Mystique
raj somaiya
Level 3:
  • Mercury Master 5,370 Answers
  • Posted on Nov 24, 2012
raj somaiya
Mercury Master
Level 3:
Answers
5370
Questions
0
Helped
3570462
Points
14579
The shifter needs to be inspected.If the gears are shifted automatically.The shifter assembly is got misaligned,it has to be open and realign.
There are many other possibilities.But if it was working right up till now and suddenly this auto shifting occurred then its shifter assembly realign issue.
Also i suggest you to refer these gear shift issues,which are mostly noticed.These are direct links with appropriate solutions to the specific problems of gear ****.
Click the link below:------
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html --------- 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html ---------- 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html --------- Car will not move when in gear? http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ----------- Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ---------- Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ---------- Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
------- 2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html -------- 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html -------- Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html --------- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
----------- Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
-------- Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
------------ No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html ------- Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html --------- 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html -------- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
---------- 1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html ------ Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
-------- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
-------- Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
---------- 2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html ---------- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
-------- Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--------- Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html --------- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------------ 2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode? http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
==========These details will help.Thanks.
  • Stephen Peter Ross
    Stephen Peter Ross Oct 30, 2014
    It is hard to find some convergence between answers and question for that one. Transmissions are required to shift when driving so is your Q just a rattle the cage question?
    Or is the transmission shift abnormal in some describable way? As it stands any answer is not helpful for a non-question.
1helpful
1988 Dodge Ram 50 Automatic shifts into park reverse and neutral. But physically won't go into drive gears.
Disconnect shift cable from transmission linkage and try to manually put transmission in drive gear ( make sure wheels chocked/park brake on ). If transmission goes into drive gear, suspect a shift cable or shifter assembly problem. If you can't manually shift into drive gear by hand with cable disconnected, suspect internal transmission/shift linkage issue
Vehicle not shifting
Have you retrained the gear? From memory think goes motor running foot firmly on brake park to neutral three times, neutral to reserve three times, neutral to drive three times, keep going thru all gears Then drive car normal for ten minutes minium as you usually would.
2008 chrysler shifts from park to drive but won't shift while driving.
try shifting from first to second to drive manuly while driving if this works bad ground on harness if doesnt work could b torkonverter problem or shift senser
Not shifting into drive
not shifting into drive......how you going 60mph? downhill with the wind behind you?
You put it in drive and its "not shifting into drive" what happens then? If it doesn't shift into drive, you're not moving. If you're moving, You can feel it shift. The rpms change. keep track.
1helpful
I have a 2000 GMC sierra 2500 truck. The guy I bought it from had a new transmition put in it. After driving a while I noticed that the tranny wouldn't shift into low gears 1st & 2nd on comand. and...
-----check possible tps [throttle position sensor ]circuit for damage or faulty sensor----if good check the fuses and trans harness for shorts damage or disconnection,check o2 sensors wiring possible ground to exhaust ,or internal leak 2nd gear apply circuit[servo assembly or 1-2 accumulator] or poor pump pressure
How to shift into 4wd
Ford has 2 types of 4x4 system engagement. One is a knob on the dash that you just turn to 4wheel drive high or low. The other system is the 4x4 transfer case shift on the transmission tunnel (hump) between the driver and passenger seats. To shift into 4 wheel drive high while driving, just let off the gas and shift transfer case into 4H position, and continue driving. To shift into 4 wheel drive Low, stop the vehicle completely, put transmission in neutral, shift transfer case into 4Low position, put trans. in gear, and start driving. I am assuming before doing the above, you have locked in ( turned the front hubs to 4 wheel drive position.) Any further questions, let me know.
1992 ford explorer not shifting right
ok... there is a problem with these sorts of things. sometimes the clutch will ge a condition called clutch dust. and its caused by grinding and hard shifting. sometimes poor alignment. take your vechile to a tranny shop and have them do an inspection on your clutch.
2003 Lincoln Navigator will not shift from all 4wheel drive into 2wheel drive
this is common on these trucks just put your witch in 2 wheel and go ahead and drive it will let loos when it sees the correct secquence and drive a little and shift to netural.
just neve do it from high to low range
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
