How can I retrieve my password to Google. I,ve forgot it.
Follow below steps:
1. Open http://accounts.google.com
2. Click "cant access your account?" below sign in tab
3.clikc "I dont know my password"
4. give your google ID
5. enter scurity string as shown in image
6. select any option for password reset.
hope this helps
SOURCE: Describe how to retrieve the asus pc password
If you can at least access root, then try the following...
All user encrypted passwords are stored in /etc/shadow file. The quick way to remove/delete a user password is pass --delete option to passwd command. First, login in as a root user.
Command to delete user password under Linux
Type the following command to delete a user password:
# passwd --delete username
OR
# passwd -d username
Above command delete a user's password (make it empty). This is a quick way to disable a password for an account. It will set the named account passwordless. User will not able to login. It is also a good idea to setup user shell to nologin to avoid security related problems:# usrmod -s /sbin/nologin usernameFor example to delete password for user sweta, Type:# passwd -d sweta
# usrmod -s /sbin/nologin sweta
SOURCE: i have a compaq Evo
To reset the BIOS password on your Compaq laptop read the information from this link.
SOURCE: Pavilion dv4000 PC Notebook: my user password ,,forgot it,,,Vista 2008 32bit ga...
For removing Windows Passwords in safety, I highly recommend windows password reset tools. Last week, and then I downloaded it and used it to remove the lost password successfully. You can download one from: http://www.reset-windows-password.com/how-to-reset-windows-password.html
SOURCE: I have laptop compaq cq60 and I forgot my
You can google search for Smartkey Windows Password Recovery to reset laptop password.
While you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Description
PSWD
Password features are enabled (default setting).
Password features are disabled.
RTCRST
The real-time clock has not been reset.
The real-time clock is being reset (jumpered temporarily).
jumpered unjumpered
To get the security code/restriction code to unlock the
cell phone from the current cell phone provider so you can use it with a
different phone provider, Please use this link and follow my instructions
Normal
0
http://www.fixya.com/support/r4350719-remove_toshiba_bios_password
I need to retrieve the password to Google Gmail. Not Bios password. I know how to unlock Bios password. There is no need for any help in that matter.
