SOURCE: Region Free Procedure for Samsung
In this unit the only thing that can be modified is the region for the dvd, not the one for the BR. Follow this
1. Press RETURN (bottom left)
2. Press the access code corresponding to your dvd zone
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
6 - 2 4 4 6 2
3. Your current region code will appear top right of screen, Press 9 to
change to region 9 (no region).
SOURCE: hack
With no disk loaded:
Press the Menu button on your remote control
Press the 5 button on your remote control
Press the 7 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
The currently selected region will be indicated on the onscreen display
Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on,
or the 9 button for multi-region playback
tried this a couple of times but got no joy, but then on my third attempt I pressed the open/close button on the remote by accident instead of pressing Menu twice & hey presto my sr150m is now multiregion!!
Give it a go
SOURCE: I have a Samsung BD-C6900
I have sought to change mine to all regions, but have had no success, yet.
Here is a link with some info that might help.
http://forum.videohelp.com/threads/232568-DVD-Hacks-List-FAQ-%28region-free-macrovision-free-others%29
SOURCE: region hack code for samsung dvd-p241
You can try to use this tip,
which is generally used for all these Samsung models:
DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105
E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530.
I think that P-241 is about the same of P-233, which is unlocked with
this tip. You can try, and then answer me if worked.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT then the following codes for the required region
the player is already set to (region you bought the player in) do not
confuse this with the A-B button:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may
need to push the tray shut rather than use the player button, in order
for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray.
Next time the player is turned on it will set to the region specified.
If the player halts on the FBI Warnings, press Forward Search x2 or
faster.
On some models, you will have the ability to disable Macrovision,
but you will have to turn off the Quasi-PAL option and set the SCART
output type to Video rather than RGB.
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
