I can't see some of my installed java applications on my samsung j210. When i found that problem, At first all applications got invisible, after few days default applications provided with phone got visible, but rest all applications that i have installed on my phone still can't be seen. In the memory status , java memory is filled with those hidden java applications. Now i am able to install new application but memory taken by hidden applications is blocked. is there any way to deal with this problem? how to delete all java applications or clear java memory?
The application you are running may not work with the version of Java currently on your phone. You need to refer to your users manual on errors of application faults.
you can only install and play java games by downloading the java games from internet directly from your mobile's default browser. you can't install java apps from memory card or pc. but please don't forget to rating my solution.
for installing the java application in your samsung mobile phone. you have to access internet from your mobile then download the jad or jar file. then it will automatically install the java app. if u can't access the internet from your mobile then turn on the bluetooth then send the files from any other mobile to your :)
1. U have a firmware that has locked java install, it's not that the apps are not susported it's just locked.The solution is easy, but needed a little of work first u need an java app like Bluetooth File Transfer or MiniCommander(i recommend it).
Download it from net host it on a wap server and download it from the wap. after u will install it run the app if u have the jar file create a jad from MiniCommander File->create jad or use Jadmaker then copy the files to your filesystem folder go to admin menu *#6984125*#>Internals>*#9072641*#>Storage settings>Update Java DB and its done it's installed without installing new firmware ;)
samsung projection java applications only if downloaded directly via WAP on your phone. A system to remedy this problem, this is Crack the phone but the procedure is somewhat risky is found on the Internet and unlock some hidden functions
This error may be because of 1. the JAR file size limit on your cellphone. 2. the file itself is corrupt. 3. the file has install site locked. (some java games can only be downloaded and installed from a particular site)
It seems that you can only download games from internet. As soon as you click on java app/game file link in the browser. The Java install options appears and the app/game is installed.
I tried all ways to install games from PC to cellphone. But so far I am unsuccessful.
it didn't help
hi dear i also have same problem
