I plugged in speakers to both ports at the same time. now i have no audio
SOURCE: COMPAQ PRESARIO SR1010V!!!
If the hard drive is is not damage maybe you can save all important files on it.
Please do the step by step troubleshooting of your laptop.
REmove the following:
1. Memory
2. hard drive
3. processor:
4. Battery
try this;
1. Fix some other connection inside the laptop
2. Insert AC plug then start the system.
3. shutdown the system
4. Insert the processor
5. swittch on the laptop.
If beeping; continue
step 3;
6 insert the memory.
7. start the system
8. If display, connect the harddrive.
in step 5: if not beeping:
Either board or processor is dead.
IN step 8.
9. start the system.
10. if the hard drive is detected, and cannot continue booting
i recommend you to reinstall the windows.
Please notify me if problems arises. i will give you further instruction, melnavz.
SOURCE: My usb keeps sayin power surge on hub ports
You may need to upgrade to a higher wattage power supply, which would also help with the performance of your computer. Or try updating either your system bios or USB drivers.
SOURCE: bad front USB ports on a Compaq Presario 5000
please re-insert the cable of the usb to the motherboard. i believe that there are 4 pins on usb1. now if this usb1 doesn't work, try the usb2. be careful when inserting the cable.
SOURCE: I need to replace that front usb ports on my
I think it would be much easier for you to use a USB hub instead.
It's much more easily available .
You can connect the hub to one of the rear USB ports
SOURCE: what brand or type of ethernet port compatible to
Intel Pro VM 10/100 is what network card HP/Compaq integrated into that computer's mother board.
