Until yesterday all worked fine. today tivo and printer do not work and lights 2-4 stopped working. did the usual unplugging and resetting and nothing positive happened
SOURCE: problem with a 704 p router
to do a hard reset, hold for about 5 seconds (don?t hold too long) and then release. (Or, release when M1 and M2 flash at the same time.) The M1 amber light flashing means that the system is active. Go to your routers settings by typing 192.168.0.1 and make sure that enable DHCP is showing and that the network adapter cards in your pc's are set to obtain an ip address automatically, to do this start>control panel>network connections, then on your network adapter ensure it says enabled, if so right click on it and select properties, go to TCP/IP line and click properties and make sure obtain ip address automatically is ticked, ok it and restart pc and see if you get a connection.
SOURCE: Power and status lights off
Sounds like you may have been hit with a power surge. If you've unplugged it and let it sit for a while unpowered, and you've hit the reset button most likely the unit is broken.
SOURCE: D-link EBR-2310
You need a FIRMWARE UPGRADE. Download the latest firmware for your router. So the router still got lights on it. If the pc connected to the router can access the router configuration page, you still have a chance in upgrading the router. Assign a static ip on your pc(192.168.0.5) so that you will have a stable connection between the pc and the router during the firmware upgrade.
Good Luck
SOURCE: D-Link Wireless Router WBR-2310 no reception
There can be a problem with the router, first thing that you can do here is to reset it by pressing the reset button of the router for 30 seconds while the power is ON then after that unplug the power of the router for 10 seconds and if you still have the setup CD you can just run it to your computer to reconfigure the router back but if not you need to manually configure the router and also do a firmware/software update for the router and if you're not familiar that you can contact this number so a tech can wlak you through with the process of checking the router and making it work again, this is the number that you can dial 1-877-787-8749 for help......
SOURCE: just got a dir615 from virgin media. lan to pc not working
If the lan light does not light up, there is a problem with the connection between the pc and the router. Did you use the cable between your modem and your pc as the cable between your router and your pc? If so, it may be the wrong cable. With some modems the suppler sends a cross over cable. This will not work between your router and your pc. Get a straight through cable and try that.
If that does not work, we need more info to help you more.
1. What is the IP address set to on your PC. See the TCP/IP properties listed in your network connection properties in the control panel.
2. Does your PC work with the modem directly?
3. Does the cable you are using have a cross-over label on it?
4. Are you trying initially to connect to the router via a wireless connection? You should use a cable connection to set up the router, then try the wireless connection.
good luck, and if any of this solves your problem please leave feedback. Otherwise send more information.
