The radio in my 2002 saturn lw 300 seems to short out. it quits & then starts working again. some times for a long time. seems like the amp is not working. where is the amp located ?
Yes it can be Amp problem,but there are many other possibilities like loose connection,radio wires getting short. http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html ------ ------- ------------- http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html -------------- http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
------------------ http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html --------------- http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html ------------- http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html ------------- http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html ---------- http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html --------- http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html ------- http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html --------- http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html ------- http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html ------ http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html ---- http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html ---------- These
details will help you thanks.
I suggest you to go through the troubleshooting help links related to car radio problems.
Click the link below:-----
Radio goes ON and OFF while driving?
Cigarette
lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe
mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on
1990 Toyota Celica?
Radio Stereo Wiring Diagram
for 1991 Chevy 1500?
How to remove radio on
Acura Car models?
Where is Radio Fuse located
on 2007 Dodge charger?
How to reset Radio code
after car battery is died?
Can car radio code block
Passkey anti theft system ?
After Market Stereo wiring
for 1999 Chevrolet Silverado 1500?
Chevy car radio doesn't
allow to switch to the XM Band to get the radio ID?
No power to radio on 2005 Toyota Scion Xb?
Lexus rx330 Radio has power but no sound?
Lincoln Town Car Radio stereo
wiring?
Radio wiring diagram for 1997 Lincoln Town Car?
How to remove cd player from dash on 2003
Lincoln Aviator
SOURCE: How to program a keyless remote transmitter fot
the only way to program the remotes is with a scan tool that the dealer has
SOURCE: replacing a fuel pump on a 2002 saturn lw300
You can check in the trunk and remove the felt cover see if there is a round panel cover that you can remove to get to the tank. If your unlucky and have to remove the tank you will have to remove the tank. The cover may be under the spare tire so pull it out. It is not to difficult to do, if you drive it till the gas is almost out you can remove the two bolts that hold the tank in place. Use wd-40 to spray on the bolts and also spray the hinges on the oppitse side of the straps. once the nuts are off drop the tank down. You will need to pull the screws off the tank filling tube so it will come down as well. drop the tank down far enough for you to get to the fuel tank sending unit. it will have philips screws holding it in place. Mark two spots with a felt tip pin, (Sharpe) white is better and mark two holes so you can line the it back up for the holes and the hoses. disconnect the fuel line and return line disconnect the battery of the car for safety then pull the wires off it can be a plug or it may have nuts on them. When you remove the nuts or screws out pull the pump out and you will have to angle the pump to get the float out. I recommend that you replace the pump and the sock on the end of the pump. Do not buy after market buy factory replacement only you only want to do this once. mark the new pump holes on the pump using the old pump as an example, will save a lot of time to get it to fit in and match and the lines will line up, tighten all screws up put the lines back on and the clamps and reinstall the tank in place. yo can use your knees to hold it in place till you get the clamps lined up and started. Screw the nuts down till tight and your set to go just hook up the battery again and your set to go.
SIde Note, Never let your car get below 1/4 of tank of fuel, the reason is gas is the coolant for the pump if it goes lower than that the pump will heat up and will burn out. Many people don't know this so I thought I would add this to your knowledge
SOURCE: How to unlock radio in 2005 saturn ion
It may be complicated, depending which radio you have. UC1 or US9, US8. The owners manual should have all the info you need. You do have the radio code, right? If not...you will need to visit the dealer. If you have the code, the radio must be on for 1 hour and then it will unlock when it reads - - - - , and you can put the code in. Its not your girlfriends fault. ; )
SOURCE: Saturn 2001 LW-300 Saturn blower motor will
Most of the time this has to deal with a poor ground connection. Everything around the motor is plastic so the ground wire is the only place the motor ground. I gave up trying to find the problem connection and attached a secondary ground to the motor and fixed it. U get to the motor under the hood in between wipers. Remove filter -remove 4 screws on blower cover. The blower slides out. attach a ground wire on the rear screw on the motor. Find a good ground for that wire & your done. I put a small hole under the blower and attached it to the frame ground right behind radio. Any good ground will work.
SOURCE: We changed the fuel pump
No, there is valve timing which is position of the valves in relation to the position of the pistons and ignition timing which means when the spark occurs during the compression stroke. Neither of those are affected by replacing a fuel pump or filter. You should have a mechanic look at it before you replace any more parts. Labor can be expensive, but so is replacing parts and still having the same problem.
