I have an older GE Stove top burner that only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
its not glass top... its the two big burners both only work on High,,, the two small ones still work normally
