Hey theres a red bar accross the top of my tv. I can see the picture but its kind of pink over it. It showed up about 2 months ago. I took the bulb out, and it won't come on now. the red light flashes at the bottom.
First things first. If you took the lamp out of the chamber, make sure the lamp is back in place correctly. You may have to "snuggle" it up a little with your fingers (not too hard, just make sure it is in the chamber properly). Then put the door back on properly, which can be a hard thing to make sure of on this set. If you feel any resistance, it is not on right. It should go in and fit just right. Lock it down with the bar, and try the power.
The red stripe across the top is something I'm seeing more and more of these days. The optical block on this television is showing some of the same symptoms that the older ones have been showing for years. They go bad.
I'd call Sony (you can look up the number on the sony website for customer service). Ask them if there is anything they can do to help you, because the optical block is quite expensive.
I hope this helps you...
Thanx. At least it works again. Ill call sony tomorrow.
