It wont let me get on to anything and when i try to open my internet connections nothing happens
SOURCE: I have COMPAQ PRESARIO F30US the wireless assistant is not workin
First check to make sure that you're wireless internet is turned on. Sometimes there is a button to push above the keyboard and others it is an FN key combination. If that does not work then go into Device Manager. Look for your wireless adapter, if there is a yellow! or a Red X, then right click on it and update driver. Finally, in Device manager right click on your wireless adapter and do a driver rollback. This will uninstall the new driver and give back your old one, if your old one was working. Repost after you tryed those three options.
SOURCE: compaq lap top presario f700 won't do any thing
try taking the hard drive and memory cards out then turning the computer back on without hard drive and memory cards for 1 minute then power it off (unplug it ) then put the memory cards in only then plug cord in turn unit on for 1-3 minutes then power down (unplug it) then add hard drive make sure there is no power going to the computer when adding the hard drive to the unit. at this point do let the unit set for 8 hours then try rebooting it should restore itself. if this don't work sorry there is a limit for what I $hare online.
SOURCE: compaq presario 2700, right hinge broken
You can buy hinges on Ebay. Make sure u get the hinge not the cover or support plate. then you have to take it apart and replace it. Not real easy but can be done by amature. Let me know if you need instructions. Be happy to help.
SOURCE: compaq presario cq60 labtop- the touchpad mouse goes crazy!
os? vista, 7, x64??? ok lets get to a base point. you had a different mouse, is it still installed? Is the dongle still plugged in? are the drivers loaded? uninstall drivers in control panel. remove all traces of every other mouse, pad, pointers, etc from your cq60. in device manager you should show Synaptics PS/2 Port TouchPad under MICE AND OTHER POINTING DEVICES. if after reboot the touchpad is still not working then right clock the Synaptics PS/2 Port TouchPad in the device manager and select uninstall. reboot. let me know when you get to that point.
SOURCE: i have a Compaq Presario CQ60. I am having
reinstall the wireless driver and check for the issue
