I have an M-audio 410 Fire Wire, and i just bought a new ASUS laptop without a firewire port and with windows 8... How can i still use my card with the new laptop??
SOURCE: M-Audio FireWire 410 External Distorted Playback...
Hello have you disabled all the built on sound cards on your computers? This is a known problem. If you are going to use a great product like M-audio disable any onboard audio card. Then try to use the 410 system. If you still have the problem try changing the latency to 4-5
SOURCE: windows xp 64 bit... where is the driver?
Go to http://www.m-audio.com and select the firewire 410, then select windows xp (64 bit) and make sure that you check the box "Show Beta Versions". There's been a beta driver since 2005 ;-)
SOURCE: m-audio firewire 410 problem
Hi isterix!
I also have a 410 on a acer 1502 laptop with xp. I installed the latest driver (5.10.00.5053) and i have sound (after changing sound preferences in panel control) but it makes me peaks in the playback. I think it's due to the driver, that is the same also for windows vista. I'll try to install the previous one and i'll tell you!
SOURCE: UNABLE TO INSTALL FIREWIRE 410????
I got the same problem, but cannt find out or google it how to reset the device, found just some scripts, cannt use that, do you have some help?
THANKS
SOURCE: My (M-AUDIO FW 410)drivers had suddenly got kicked
Unfortunately, you may have to upgrade. Depending how old your system is typically you need to upgrade every 3 to 4 years. You might upgrade your RAM. When you turn on your computer wait at least 5 minutes for all your drivers to load. If you open up an application before they load it may cause a conflict and not load all drivers. Make sure your not connected to the Internet. When your connected to the Internet all your programs that are not set up to not look for updates will. You wont even know that their doing this until it's to late. This is what I would do. Go to your system restore and restore to a point that you knew it was working. When you look at your restore options it will give you a list by day what was added. Just look at these day's and try and remember what you installed before this started happening. You're having a conflicting problem. Now we need to find out where. Feel free to contact me with any other questions. Hope this helps.
JimmyC
When you install WinXP again it fail to see the sound card you will need to load the original sound driver if you dont have it then try here for it:
Theres the reason I believe when you installed XP you have install the driver for that model: XP fails to load the drivers possibly out of date and then it wont load it however you go here and find your one and install that you wont afterwards.
