Need too rewire control panel
SOURCE: control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
SOURCE: I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
SOURCE: hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
SOURCE: Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
