2003 Audi A4 Cabriolet Logo
Posted on Jan 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adui a4 there is a light on the center console and it says 1mph can u tell me what it means please
  • Anonymous Jan 22, 2009
    I think you have set the car to beep and warn you if you are exceeding a certain speed, I set mine for 1mph also when I was playing with the buttons. Look in the manual, but I think I got rid of it by holding down the reset button for 2 seconds while the 1mph was displayed.
Anonymous
Level 2:
Sniper:
  • Expert 94 Answers
  • Posted on Feb 10, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
94
Questions
0
Helped
91982
Points
285
IT IS A SPEED WARNING FUNCTION YOU CAN SET IT TO GIVE YOU A AUDIBLE WARNING IF YOU GO ABOVE YOUR PRE-SET MAXIMUM SPEED
Whats wrong with audi a4 quattro when light on dash saying 1mph
Read your owners manual on how to set or clear your speed warning. There is nothing wrong with your car.
IIRC, the speed warning is zeroed by holding down the left instrument cluster button for more than one second when the vehicle is moving faster than 3mph. The icon will show with a diagonal bar through it indicating the speed warning is turned off.
Needs radio code for 1998 audi a4
You'll have to bring the car to a dealer. With the VIN and the serial number of the radio they can look up the security code. Be prepared - you might get this done for free or a flat charge, but many will charge up to an hour's labor. Be sure they give you the code written down for future use.
Car would stutter when accelerating but not during a constant speed, 1mph light came on then the check engine light
you are having fuel delivery issues, assuming the fuel pump is working fine, check your fuel filters (usually one in line and one in the tank). chances are one of these are clogged.
1998 adui a4 why the key light lights up
You need programing your key.Only diagnostic equipment can do that
3helpful
My 2004 Audi A4 Cigarette lighter socket surrounding broken
Hello, hope this info helps...(subytech1)...Cigarette Lighter In Center Console, Removing And Installing (Vehicles Up To 10.04)
Special tools, testers and auxiliary items required
  • Torque wrench V.A.G 1783
1-Cigarette lighter
  • Removal:
  • Remove center console.
  • Turn center console - 4 - around.
  • Remove two bolts - 3 - on cigarette lighter - 1 -.
  • Disconnect harness connector - 2 -.
  • Remove cigarette lighter - 1 - from recess - 5 -.
  • Installing: Installation is reverse of removal.
2-Connector3-Screws, (2x)
  • Tightening torque 2 Nm
4-Center console5-Cut-out
I have an 2004 audi a4 63500 miles when does timing belt need changing or how can I tell if it was done recently
The timing belt interval used to be 120k, but after numerous timing belt breaks and a class action lawsuit against VAG, Adui has changed the interval to 80k..However, i have seen them break even at 70k miles. Unless you see paperwork that it has been done, just plan on replacement before 70k. Better safe than sorry, if it breaks it costs thousands!
Need help
try this website www.webcrawler.com and maybe they have a diagram for you.
1helpful
I have got an audi a4 tgi 1.9 and there a flashing light a circle and a 1mph showing.shows up when i go over 50 miles
LOOK UP YOUR MANUAL, YOU CAN TURN THIS OFF..ITS A SPEED WARNING FUNCTION TO HELP PREVENT YOU EXCEEDING A PARTICULAR PRE-SET MAXIMUM SPEED.RESET THIS.....
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Audi Expert? Answer questions, earn points and help others
