APC Back-UPS CS 500VA UPS System Logo
Anonymous Posted on Jun 02, 2007
How to repair UPS
What if the batery of the ups dosnt charge even the batery is ok.What is the problem of the ups?
  • maha4098 Mar 24, 2009
    what if the batery of the ups dosnt charge even the batery is ok.What is the problem of the ups?
  • ROLANDO JIMENEZ Oct 04, 2013
    WE CHARGED EXTERNALLY THE BATTERRIES, BUT THE PROBLEM STILLS
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
9633
Points
8
My ups got sound is what proplem
Anonymous
Level 1:
New Friend:
  • Posted on Mar 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
9633
Points
6
My UPS 1 KV suddenly gets off (all panel light gets off)then suddenly it gets on autmatically.this happens frequently in 24 hours.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9633
Points
Whenever i switch on my UPS it dont turn off.I have already change the switch but the problem is not solved
Anonymous
Level 1:
  • Posted on Feb 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
9633
Points
I fixed mine by wiring in an old 12vdc. 500ma wall wart. This powers the UPS circuit while at the same time it keeps the battery topped off just like the internal circuit is supposed to... but no longer does.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jun 04, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
21241
Points
21
May be a number of problems fuse in mains plug fuse in UPS unit may be the battery is 'floating'
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
9814
Points
7
Most of the times, if not the battery is dead, is one of the electronic components inside. I bet that most of the times is one of the capacitors, but is not easy to know which one.
I suggest to visit this site:
http://www.heime.org/Lists/Posts/Post.aspx?ID=17
and get the inspiration to find the way to fix your UPS trouble.
Anonymous
Level 1:
New Friend:
  • Posted on May 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9633
Points
My ups just works on battery it doesnot change to power even if it is connected to the power switch.......
Arpan
Olimpio Portilho
Level 1:
New Friend:
  • Posted on Sep 24, 2015
Olimpio Portilho
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
9633
Points
7
I have a Smart-UPS® RT UPS that is lighting the LED internal fault. Can anyone tell me what UPS circuit monitors this internal fault to myself repair the board? This failure is default PWM circuit or the control board?
  • Md. Adib Ibne Yousuf
    Md. Adib Ibne Yousuf Nov 10, 2015
    It has problem in control board.
A
Anonymous
My problem is when electric supply is down then our power is connected to the ups through the MCB.why mcb will be off.
Xavier Prathap
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Aug 29, 2010
Xavier Prathap
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
16726
Points
28
May be because of the charger fuse or the charger device inside the ups
A
Anonymous
Ups shows Over Charge on Batery mode
it might be initial record on the log,try to refresh.if its backing up and its charging i would suggest you let it be, it woulde clear as time goes on
The power wents off and the batery got completly discharged , then i turn it on and run the self test and replace icon staid illminate but in the next self test didn't, i hace to replace the battery?
First tell how old is your UPS ?
if its older by two to three years may be the Battery eeds a replacement .Try charging the battery externally with a good battery chargers but before charging externally please take out the battery outside.
Then if the battery shows very low voltage even after charging for some 8 hours then you have one alternative that is replace with new battery.and promptly keep it under charge with out fail.
Numeric ups red light indicates?
1. low batery (not proper charging due to bad or not proper acid level)
2 short circuit
3.inner ICs needs to change
BATERY NOT CHARGING
Dear Ravi,
What's the status of the Battery indicator LED? Is it flashing or....?
Best regards,
Ron
1helpful
My numeric 600 plus ups swithched off automatiocally when power goes off not a single second back up its provided
Did it work before?
If so, then it has developed a fault. Check the battery fault light on the UPS panel. Perhaps it's battery is dead, or batery charging circuitry is faulty. Anyway, it would most probably need professional attention by a serviceperson.
If it did not, double check whether you have connected the computer etc. to the proper sockets - many UPS devices have a couple of UPS-powered sockets plus additional sockets with surge protection only (no UPS power!) for high power devices like laser printers etc.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
1helpful
Mge pulsar ex10 stop after 5 min with 60W charge,after I changed the pack of 3 bateries with one new.if I switch off and on works again 5 min. all 3 bateries are good,Vcharge=13,6v Vin use=12,3v thanks
Some economics UPS have a functin called "Green Function". A timer disconnect the load after 5 min to prevent damages on internal circuit.
You can confirm this:
- battery remain to good level charge
- UPS restart for other 5 min if you press On button
See manual if you can disable this features.
No Power when turn on so battery wont charge
Try leaving it off, but plugged into the wall outlet so the batteries can charge up. If they are new, they are probably without a charge. The instructions should indicate how long it needs to charge - probably most of the day.
4answers
Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
1helpful
3answers
UPS 1800VA
You can increase the capacity of the batteries from the original equipment, but you cannot put more load onto the UPS. Your runtime may be increased, but you may have trouble fitting the car batteries into the case. Some UPS's have external connectors for external battery packs. Find one of those and add the batteries to it. Make sure that you maintain the DC voltage which the UPS requires. It may be 12 volts or 24volts. Two 12 volt batteries in Series.
Top APC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
