The machine stops a few minutes after it starts (at wash, spin or rinse). based on reviews and solutions here, I just checked the belt and it seems slightly loose. How should I tighten it?
When it stops post here what blinking lights are on.
Belt should have some movement. If you hear the motor straining but the tub is stuck then it will be worn, hot and flaking.
The water pressure switch can stop the unit
The safety switch can also stop the unit for out of balance. I would reload the washer and check if level as well. Then see if you get the blinking lights.
SOURCE: my haier washing machine doesnt work properly
get rid of it. I had two of these that did the same thing. people all over the internet are suffering with haier washing machines! They are utter rubbish and I will never buy haier again!
SOURCE: Err 7
Err7 is a motor error.Check out the following Haier washer manual link (page number 17).
for washer manual click here
The only solution suggested is to replace the motor.
SOURCE: Haier HLP21E 6.6-Lb How do I remove lint filter?
You grab the plastic top and bottom of the filter and kind of pinch it so it pops out. It's held in by small pegs on both ends.
SOURCE: dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
SOURCE: Can't find Haier lint filter for HLP21E
http://www.repairclinic.com/SSPartDetail.aspx?s=b198i1226155&PartID=1226155
My washer did not come with the Lint Filter. I contacted Haier Customer Service and sent them all the info they requested such as copy of receipt and etc. That was several weeks ago and Haier still says that they have yet to receive that letter. Or they say that due to high volume of warranty letters they receive, they have yet to process it. Anyways, I got fed up with the customer service or lack of, I started surfing the web for the lint filter and found the above site. The filter is very inexpensive and I got it in several days.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Click this link: Inlet valve
