Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
How to reset netgear wgr614 router to default settings
  • bjd3 Apr 05, 2009
    will this remove the lock so family can come in and use my wireless router
  • NetGear Expert
  • 153 Answers
Today I am Going to Assist You to Reset Your Netgear Wireless Router To Default Settings.
Let's Get to This Issue First And Understand The Real Problem With Your Netgear Router
There is Mostly Two Methods You Can Be Used to Reset Your Netgear Wireless Router.
  1. Soft Reset Using Netgear Router Dashboard
  2. Hard Reset Using The Reset Key
for more details please visit How to Reset Netgear Wireless Router TechVaidya
I hope this will helps you
Posted on Aug 25, 2018
    Master:
  • NetGear Master
  • 317 Answers
> Disconnect all the connected devices with the router.
> Unplug the power cord from your router.
> Press and hold the Reset button for 20 to 30 seconds.
> The Power-light should blink while you're holding the button.
> wait for the power light to stop blinking.
> Then plug the power cord back into the router.
> By this your router is successfully reset.
still you have problem vist https://wirelessrouterexpert.com/customer-support/netgear-customer-service/
it helps you
Posted on Dec 29, 2018
SOURCE:
Joed911
  • 4338 Answers
SOURCE: I have a netgear wirerless router wgr614 54mbps router. How do I
Follow the steps on this NetGear link:
http://kb.netgear.com/app/answers/detail/a_id/112/session/L2F2LzEvc2lkL2tjaHhOUnRq
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Mar 27, 2009
Mole72
  • 30 Answers
SOURCE: connection settings for a ps3 via netgear WGR614
you need to check your routers firewall setting by accessing your router through the pc and make sure your plug and play settings are enabled. all can be found on the router setup page. the playstation only requires you to enter the WPSK or WPA wireless encryption key to log on so the problem is usually with the router....hope this helps.
Posted on Dec 13, 2008
PC Commando
  • 142 Answers
SOURCE: xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Posted on Sep 19, 2009
Geekman
  • 32281 Answers
SOURCE: PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii
.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Posted on Dec 20, 2009
Geekman
  • 32281 Answers
SOURCE: Cannot reset my password on my router made by
Power up the Netgear and press the pinhole RESET button on the back of the Netgear until all the LEDs flash, then release the RESET button.
The Netgear is now restored to the factory default settings.
Posted on Dec 27, 2009
Install new password on netgear wgr614 router
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 29, 2012 | NetGear WGR614 Wireless Router
How do I reset my router and connect it to a different computer?
Look for a little hole that reads reset and press it with a little pin, hold it for about 10 seconds
Jan 31, 2012 | NetGear WGR614 Wireless Router
Wont take any passwords
If you have forgotten the login password, you can reset the Netgear back to the default settings by power up the Netgear and press and hold the pinhole RESET button at the back of the router until the LEDs flash.
the default PW = password
Dec 21, 2010 | NetGear WGR614 Wireless Router
I ahve forgotten my forgotten netgear password on WGR614 router. Please advise Thanks Tony
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Dec 14, 2010 | NetGear WGR614 Router
Netgear wireless router wgr614?
If you cannot login to the router's configuration URL, then you can reset the Netgear back to the factory defaults by powering up the router and press the pinhole RESET button at the back of the router until the LEDs turn on, then release the RESET button and wait for the router to reboot.
Then connect a LAN cable from the computer to the router open an Internet Browser and enter the router's configuration URL
http://192.168.0.1
The default password = password.
You can now configure the wireless settings, Eg. SSID, encryption etc.
To secure your wireless from unauthorized access, please click on this link and follow my instructions :-
Jul 11, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Problam
you will have to reset the router to factory settings and reconfigure it to your custom settings. To reset the router you must depress the reset button at the rear of your router. Connect the computer and the router using a cat5 cable.
Go throught the setup in the manual that can be downloaded from
http://www.retrevo.com/support/Netgear-WGR614-Wireless-Routers-manual/id/420dj080/t/2/
While you are at it you might make sure you have the latest driver.
You can find the correct driver for your version of the WGR614 at
http://kb.netgear.com/app/products/family/a_id/1296
Please rate this solution. Thanks.
May 30, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
How to set a password for my wifi netgear wireless-G Router?
try 1234 as the password. failing that go to this page for instructions on how to reset the password. http://kb.netgear.com/app/answers/detail/a_id/9665
there is even a video on how to do it but be aware that this will reset your rounter to factory (default) settings.
robert
May 11, 2010 | NetGear WGR614 Wireless Router
If you want to reset your router to its default settings what yu need here is a Pen or a Paper clip to do the procedure but before I provide you those , let me first tell you that doing the reset the router will be back to its default settings like a new router that don't have any configuration inside it and all your settings will be wiped out.
But if you want to reset the router look for the reset button on the router usually its located on the back or at the bottom of the router so while power is ON press and hold the reset button of the router for 20 seconds and then after that power it OFF for 10 seconds and when you power it back ON router is already reset to its default settings and you need to reconfigure it back.
Jan 23, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Cannot reset my password on my router made by Netgear can you help Netgear router WGR614
Dec 26, 2009 | NetGear WGR614 Wireless Router
Open Questions:
RR MAIL +1800 246 7609 tech Support phone number VK We admire 1800246-7609 Tech that is report RR MAIL tech support phone number for good support and service provides truly by phone. Then used number is printed on a label. You have to might needs to be closed the link cartridge access the area of scanners .RR MAIL is about to login on for Step ahead Get our easily access to Our Private meeting Or Tech, Any error recommend You call by Our Toll free. , RR MAIL is the most and most trusted Our Tech support Features For RR MAIL phone number for RR MAIL that software we have. Our technical support help team our RR MAIL will totally support you in completely removing the viruses and malwares phone from your number computers and Laptops. startup support have good furious above share RR MAIL tech support phone numbera contact the story VIKKI-boss We admire 1********** Tech that is report RR MAIL tech support phone number for good support and service provides truly by phone. Then used number is printed on a label. You have to might needs to be closed the link cartridge access the area of scanners .RR MAIL is about to login on for Step ahead Get our easily access to Our Private meeting Or Tech, Any error recommend You call by Our Toll free. , RR MAIL is the most and most trusted Our Tech support Features For RR MAIL phone number for RR MAIL that software we have. Our technical support help team our RR MAIL will totally support you in completely removing the viruses and malwares phone from your number computers and Laptops. startup support have good furious above share RR MAIL tech support phone numbera contact the story VIKKI-boss
Jun 25, 2019 | Team Computers & Internet
See all NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER Questions
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
52,956 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
