I replaced the light engine in my Hitachi 60v500a and I now have a 1' black bar that runs across the bottom of the screen. I believe the rastor needs to be adjusted but I cannot open the I2C service menu. The power button on the tv is no longer working. Is there any other way to fix this problem?
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back
the adjustment values from your notes to their respective adjustment
parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT
Button is pressed on remote after every change to the values. Failure
to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
The problem is that the power button on the front of the TV is not working so I can't open the I2C menu. I wanted to know if there was any other way to enter that menu without using the power button. Thanks
