I have a class that comes on tv at midnight, but I go to bed well before that. Is there a way to set this VCR to record a certain time period? The menu screen has a "timer recording list" function, but when I go to it, it just says "there are no recordings pending..." or something like that, with no option to actually set a recording. Thanks!
Unable to record TV programmes using the electronic programming guide. An additional note about setting the timer is shown on the screen.Unable to record TV programmes using the electronic programming guide. An additional note about setting the timer is shown on the screen.
You can't post conmments that contain an email address.
Do you have your operation manual? It will tell you how to set up a timed recording. Recording options are set via the remote. Look for an option as "Scheduled recording" or similiar. Date, start & end time, channel, recording speed are all set.
If you are missing your manual do a google search with your model number. A quick look at the Samsung website was not fruitful.
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
you can try setting your tv to record and your vcr to record at same time,,,i have digital tv and set record time,,then on vcr set to record avi at same time,,the only problem is the tv turns itself on when timer starts,, hope this helps and makes sense,,cheers.
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording the VCR clock / date must be set and not flashing 12:00 then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
Hi, After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel. Let me know if you have additional question. Thanks.
Timer Recording JVC VCR HR A591U Timer recording can be programmed on-screen with the remote control. The built-in timer allows automatic unattended recording of up to 8 programs within 1 month.
EXAMPLE: Program a timer recording for the 26th day, channel 125 (CATV), 11:00 - 11:30 PM on timer program number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the TV and this VCR on and select the video input mode on the TV.
• After timer recording is completed, the VCR turns off automatically. • You can program the timer recording while a regular recording is in progress; the menu screens will not be recorded. • The timer recording will start at 20 seconds before the time you predetermined.
Press MENU on the Remote. Check the “TIMER REC SET” option is selected, then press ENTER.
Press SET –/+ to select one of the program lines, then press ENTER.
Press SET –/+ to select the date, then press ENTER.
Set the start time, end time, channel and tape speed as in step 3. NOTE: To record from external source, press SET –/+ and set the channel to "L". "L" will appear next to CH 125 (or 69).
To enter other programs, repeat step 2 through 4. Or, press MENU twice to return to the normal screen.
Press TIMER on the Remote. The power will go off, the TIMER REC indicator ( ) will light and the VCR stands by for recording.
To cancel a program:
Press the SET –/+ to select the “TIMER REC SET” option in the MENU. Then press SET –/+ to select the unnecessary program, and press CANCEL to cancel the program.
Here are a few items to check and how you need to set your recording.
1. Your HD box should have a coax out (or to TV) connection on the back of the box. 2. Connect a coax cable from the back of the HD box to the "RF IN (FROM ANT.)" in the back of the VCR. 3. When you set your VCR to record you need to set it to copy channel 3 and tune the HD box to the channel you want to record. This should fix your problem...
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
SET YOUR TO RF LEVEL " LOW" OR YOUR CABLE CONNECTION IS WRONG CHECK IT.IF THE PROBLEM REMAINS, CHECK IT ON STANDARD DEFINITION TV FOR RECORDING.IF THE PROGRAM RECORDS OK THEN IT ID NOT COMPITIBLE FOR DIGITAL SIGNALS. BUT IF NO RECORDINGS PERFORM CHECK THE VIDEO HEAD CLOGGINGS OR MAY BE MAIN "IC" PROBLEM.
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
