I have transferred some Digital 8 cassettes from my old Handycam on to DVD via my LG DR 275 but they will not play on any other device... Including my laptop or other DVD players.
SOURCE: LG DR-4810 DVD Displays " PLEASE WAIT"
C113 10v 1000uF cap off an XFRMR in power supply board. Cooked and gone high esr. Replace with a 16v.
SOURCE: How do i hack into the LG DR275 Recorder to make it region free?
Press setup, go down to the lock symbol. do not enter it, just have it highlighted, then press "0" seven times. this will make it region free. also applies to most LG DVD players and DVD recorders.
SOURCE: i have got an lg dv-275 dvd recorder, when i
Try getting a laser lens cleaner, you are supposed to clean your lens every 10 hours of use, also, listen to see if you hear the motor spinning when you insert a disk, if you can't, well, you know.
SOURCE: I have an LG DVD Player/Video Cassette Recorder
Turn on the unit and open the tray. Press 0000 on the remote to access the DVD region code selector.
Change the EEPRom code to 0 to remove the region lock.
Press Pause to exit the screen and your LG V271 should now be region free.
