My washing machine is not heating and making lots of noise when spinning.Machine still working perfectly but the water is not heat from any temperature, if set on 60 degree temp the programme will take longer or even repeat at the end of the course as it had not heat. when spinning it make lots of noise as if these is something loose inside.
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
SOURCE: Noise at end of spin cycle
Sounds like the drive block is defective. The drive bloce is a aluminum part that attaches the drun to the gearcase. If you remove the agitator you will see a large nut on top of the basket. If the drive block is worn yo will see aluminum peices on top. It is very simle to relace. You will need a spanner wrench to remove the nut. With the nut removed lift the spin basket up and out. Remove the block. You will see that the new block will only fit on one way. Tap it down untill it will not go any further, replace the basket, make sure you tighten the nut securly replace the agitator and you will be back washing.
SOURCE: washing machine won't spin
The lid switch is likely defective. Test with a VOM meter and replace as needed.
SOURCE: WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
SOURCE: Washing machine
f63 shoes on machine
siemens e 12 46 is the machine only 4 months old is there anything i can do befor i call an engnieree
Bosch maxx6
still waiting for a solution
