I have a Dell Inspiron 1000 thats fried ....I have the
FUJITSU Mobile MHT2040AT - hard drive - I'd like to just stick it in a newer laptop - How can I find which ones will work with it ?
u'll have to search for them yourself.... there is no list... try with the laptops that are more than 1.5 years older (as a model not as production date)u'll have to search for them yourself.... there is no list... try with the laptops that are more than 1.5 years older (as a model not as production date)
You can't post conmments that contain an email address.
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
its fryed the GPU, sorry it won't work anymore, unless a miracle happens. If it was off and you left it off until it completely dried out (6-7 days) it would of still worked.
Error code 1000-0146 is a hard disk drive failure, you'll need to replace the hard drive. If under warranty contact Dell for a replacememt. If not, you can buy replacements at newegg or other tech sites
Check the disc for scratches, this could be a bad disc. However, I'm leaning towards another issue besides the hard drive being bad. Tell me what initially happened to make you buy a new hard drive. Hard drives aren't effected by the heat produced by the machine, so tell me what made you think it was heat that caused the hard drive failure.
So, how do i determine what other models my hard drive would fit ?
Is there a list on line somewhere ?
