My cell phone will constantly change 'status' saything that the 'chip' was removed, then if I apply pressure or something to the phone then it will say that the chip was reinserted. But now even with the chip in, my cell phone won't read it, and I have lost all my pictures and music. HELP!
SOURCE: my computer nor samsung alias wont read my 4gb pny microsd chard
I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
SOURCE: My PNY 2GB microSD Memory Card Problem is cannot
you can formate it first you right click on my computer the go to manage option and then go to disk management and then write click on your memory card drive and then go to option format
this will 100% be usefull
SOURCE: i forgot my password of my 2gb microsd memory
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
Please rate this solution, if it works
Rnj VinodKumar
SOURCE: my microsd 2gb memory card
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
