Question about Samsung RB2155SH Bottom Freezer Refrigerator
My model RB217 ABPN, Fridge not working
It started with some noise and then the temperature indicator was flashing. When I unpluged and pluged it again, refrige stopped working.
SOURCE:
SOURCE: No display panel indications on Fridge freezer
We had the same problem due to a power surge- we pressed the power cool and power freeze buttons at the same time until it reset and it's fine now. Hope this helps!
Posted on Sep 26, 2008
SOURCE: MY SAMSUNG FRIDGE/FREEZER HAS A PROBLEM MY
This is caused by the ice building up in at the back - the fan catches the ice and eventually will stop. With the fan malfunctioning the temperature will rise and the light then flashes. Keep searching the web, and you will find instructions how to remove the back and de-ice it. I had exactly the same problem 2 months ago. Make sure that it is fully de-iced, including the tray at the bottom. Ours has worked OK since!
Posted on Aug 08, 2009
diodeic
  • 1622 Answers
SOURCE: I have a Samsung RS2555SW Side by Side Fridge.
Your fridge not working is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help in solving the problem. Take care.....
Posted on Oct 03, 2010
  • 1456 Answers
SOURCE: The fridge temperature display won't
Hello
Run a couple of system self test on the refrigerator to see where the problem has occured
Inspect your condenser fan and get a multitester to test the thermistors if they are still in perfect order,if they do not give accurate readings you should replace the condenser fan and thermistors.
Also check out the fresh food evaporator fan if it has not been iced up as this can restrict air flow and make your refrigerator not to cool
The evaporator fan is behind all the plastic back wall and insulation.replace the fan and the thermistor near the top light and clean out all the ice.
Your refrigerator should now work normally.
Posted on Dec 26, 2010
baraquielnar
  • 247 Answers
SOURCE: My fridge - model RS583HDP
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Posted on Feb 13, 2011
Why would the freezer and fridge temperature indicators flash after a few hours of the unit being switched on?
Hi, some fridge freezers the indicators flash as they have not got to the right temperature yet. Also some freezers have indicators that will start flashing to let you know that the door has been open to long and the freezer temp has risen.
Jan 20, 2016 | Refrigerators
Model E402b. Why is the alarm going off?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Apr 25, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
Feb 13, 2011 | Samsung Refrigerators
We pluged it in and it worked and now it dont
If you changed the settings or unplugged it or the power to the house went out, then you have to wait a few minutes before the compressor can start up again. There is a sticker on the fridge that warns about that.
If it still hasn't started up when you read this, then:
1. Set the temperatures where you want them for the freezer & refrig.
2. UNPLUG power cord for 10 minutes (don't open either fridge or freezer).
3. Wait a full 10 minutes! Nothing will melt... check breaker to outlet, just in case...
4. Plug in power cord... It will start now..
Hope this helps!
Sep 15, 2009 | Amana Refrigerators
Fridge does not get cold, lights are flashing and whoo whoo noise
Lights which previously did not flash but now do are clear indicators of operating failure.
Refridgerators and freezers do not like being unplugged for too long. if yours has been disconnected from the power for more than a couple of days, it could be damaged and need part replacement.
The variables are cold leakage, cooling gas leakage, electrical pump failure, thermostat circuit open, thermal cut-off switch disconnected. All of the above can be dangerous - electricity, gas, over-working pump etc. so always remember what we learned in kindergarten - If in doubt don't' - good advice with anything risky.
If you set the fridge on the coldest setting, place a common thermometer inside, note the initial temperature after closing the door for 15 minutes and then leave the fridge door closed overnight, in the morning carefully touch the heat transfer coils at the back, they should be hot all over to the touch. Open the door and check if the temperature has dropped.
If the whoo whoo noise is coming from the pump (often located in a black closed saucepan-sized unit you need to contact a qualified Whirlpool fitter.
If the whoo whoo noise is coming from around the edge of the door, the airtight seal is possibly defective. The seals often get dust etc. trapped in the accordian-like sealing strips around the entire door so, being careful not to damage the seal, clean the inner grooves - an old toothbrush and household cleaner generally work well.
If the fridge is a self-defrosting type, the lights may be indicating that it is stuck in defrost mode - check the Whirlpool website for troubleshooting temperature settings. There is often a small regulator switch which can break down. If you think that this is where the noise is coming from do not go fiddling about - electricity is a to be treated with care. Look for scorch marks or listen for crackling noise indicating a short sparking. Unplug the fridge before poking around the wires. A connector may have been dislodged and needs to be reattached so double-check that the power is off before reattaching the loose wire. It should be obvious where it plugs in but if not, don't go touching different tabs.
Re-read the installation and operating manual or call a fridge repair service if you are unable to find the fault. You can save time and repair costs by telling the repair person what you have tested and the results.
The built-in thermostat could be malfunctioning and preventing the coolant coils to absorb heat.
Sometimes the defrost drip tube can become blocked. This generally runs down the back into a drip tray. You should be able to check for blockage by thoroughly cleaning the tray end of the tube and blowing through it. Don't ****.
I hope this helps,
jenni.
Sep 09, 2009 | Refrigerators
MY SAMSUNG FRIDGE/FREEZER HAS A PROBLEM MY TEMPERATURE ON THE FRIDGE IS FLASHING. THE MODEL NO. RS21DCNS THE FRIDGE IS NOT COLD ENONUGH AND I PUT THE TEMPRATURE ON HIGH AND IMMEDIANTLY IT WENT BACK DOWN....
Jul 07, 2009 | Samsung Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Samsung RB2155SH Bottom Freezer Refrigerator Logo
174 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
