RTO Gas Motor Scooter Logo
Larry Shaw Posted on Nov 21, 2012
What is the fuse size for my renegade 50cc i do not have a clue.thanks
Kymco agility 2012,i want to put a 72cc big bore kit on it,at mo running standard 50cc carb,was told i need to up my jet size.
Use a numbered drill set, measure the jet size using the drill bit set, then select a drill bit two numbered sizes larger and drill out the main jet, that should get you in the ball park. Here is a link to a numbered Drill bit set. 60 Pc Titanium Nitride Coated High Speed Steel Numbered Drill Bit Set
2answers
2004 jeep liberty renegade 3.7L fuse panel instructions
The fuse panel consists of fuses that should not be blown and relays. A test light is a very handy tool to check both sides of the fuses.
If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
1helpful
2answers
I have no dash lights in my 2006 jeep liberty renegade. I cant see a fuse for this. what else could it be
Most likely, you have a dial or switch to adjust the brightness of the dash lights. Make sure it is not turned all the way down. Also, on some Chrysler vehicles, you are also able to override (turn off) the overhead interior lights by turning it all the way down, so you can leave doors open without draining the battery. If that is not it, there is a fuse for your dash lights. Refer to your owner's manual for the fuse position in the fuse block, as well as the correct type of fuse and amperage rating.
3helpful
I drive a jeep liberty renegade 2005 model break and tail lights
check brake switch under brake pedal... if not working change it..
1helpful
My electric start dont work.!
The battery is the key. The starters are pretty durable so make sure you a using a charged attery with good contacts. Also, check the fuses, you may have a blown fuse that wil prevent you from turning the starter.
1helpful
My son's 2005 Kymco TGB 50cc scotter hit a good
Normally, one goes to the carb, one to the gearbox and one to the battery. What sounds really weird is the diameter of the hoses. Three quarter and one inch diameter? Normally 1/4" to 3/8".
Hope this helps!
Please rate this solution. Thanks locjaw69!
Top RTO Toys Experts
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Jerry Ross
Jerry Ross
Are you a RTO Toy Expert? Answer questions, earn points and help others
