Hi Gerard, on a 1.28v Punto the plugs are on the back of the cylinder head tucked between the 4 inlet manifolds. The plug closest to the timing belt end (just next to the oil dipstick) is easy to find, the others are a bit obscured by the plastic housing that sheaths the injector wiring. Be careful pulling off the suppressor caps, they hang on quite tight so best use long nose pliers and NOT pull on the HT lead. Hope that helps. Andy
Use only a single-outlet surge suppressor that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps. There must be a monitoring light on the surge suppressor to indicate whether it is functioning properly. Failure to use a properly functioning surge suppressor could result in damage to the control system of the treadmill. If the control system is damaged, the walking belt may change speed or stop unexpectedly, which may result in a fall and serious injury.
