Question about Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002
2000 s500 key will not turn
Key will not turn
3 Suggested Answers
SOURCE:
BillB-SA
  • 2761 Answers
SOURCE: My 2000 Mercedes Benz S500 is dead- electronic key does not
It's not that unusual for a battery to fail that soon, and the "no lights, no nothing" says that it's the battery again. Your best bet at this point is to pull the battery and take it to the point of purchase for testing. They should either replace it under warranty or charge it for you. After you replace the battery you should have the charging/electrical system checked for possible shorts or power drains.
BillB
Posted on Feb 09, 2010
  • 26 Answers
SOURCE: 2000 s500 will not start,but key turn
next time you try to start the car just put the key in and turn the ignition on dont try to start it to see if your security light comes on. if any kind of security light come on or flashes call a dealer to find out how to reset the system. if u have the wireless transponder for the security the battery may have gone dead
Posted on Jul 30, 2010
My 2000 S500 mercedes will not start. the key turns but the engine will not crank. it has a new battery
Does it click or do anything? If not, then the plastic gears inside the ignition that control the vehicles ACC and ON positions along with the cranking may have slipped. Have someone to pull the ignition switch panel and check and make sure the "gears" are working properly.
Feb 23, 2014 | 2000 Mercedes-Benz S-Class
My trunk on my 2000 mercedes s500 will not open. Battery is dead. Tried the manual lock. I am pushing it in and it still will not open
my truck on my s500 2000 model will not open at all, not will the key and not on the door the key doing everything it suppose to do with the windows and the sunroof, bnut them truck will not pop up could it be a fuse or is the the lock is stuck
Jan 29, 2011 | 2005 Mercedes-Benz CLS-Class
Jul 30, 2010 | 2000 Mercedes-Benz S-Class
I own a 2001 s500 mercedes benz. I put my key in the ignition and tried to turn it but it would'nt turn. What could be the problem/?
Steering wheel is 'locked' - move it left or right while trying the key. Or make sure the gear selector is fully in Park, if an Automatic.
Apr 21, 2010 | 2000 Mercedes-Benz S-Class
I have a 2001 s500. How do I replace the
Slide catch on top of key to remove emergency key
Use this or small screwdriver to prise off top cover of key to see battery
Apr 09, 2010 | 2000 Mercedes-Benz S-Class
BillB
Feb 09, 2010 | 2000 Mercedes-Benz S-Class
Turn signal bulb 2000 Mercedes s500
If you have a owners manual then the method is described there.
Sep 13, 2009 | 2000 Mercedes-Benz S-Class
How to change the battery in the key fog
I had the s500 2001... so u have to take the steel emergency key off then introduce it obliqually and push it will open! ...not easy to explain better but any mercedes service can help u easily and quickly!
Jan 08, 2009 | 2000 Mercedes-Benz S-Class
Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002 Logo
75 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
