Delta Faucet 2100LF Classic - Double Handle Kitchen Faucet with Metal Knob Handle Logo
Dale Wainwright Posted on Nov 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking faucet repair procedure
Todd Arndt
Level 3:
Top Expert:
  • Master 2,044 Answers
  • Posted on Apr 12, 2013
Todd Arndt
Master
Level 3:
Top Expert:
Answers
2044
Questions
Helped
584570
Points
5934
Secure your water
Determine the cause of the leak
Change the Seal on that side (Double Handle)
Change Cartridge on Single Handle
tip
How to repair disc-type faucets
DISC-TYPE FAUCETS
  • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
  • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
  • Use pliers to pull the disc assembly out of the faucet.
  • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
  • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
  • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
  • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
  • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
on Jan 16, 2010 • Plumbing
1helpful
2answers
Bathtub faucet leaking a lot
Change the gaskets.
Popular Grohe 3427 Concetto... Repair Questions - Fixya
www.fixya.com/support/p1162411-grohe_3427_concetto.../popular
Popular Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair ...
Grohe 3427 Concetto Single Hole Bathroom Faucet ... - Fixya
www.fixya.com/search/...grohe_3427_concetto.../grohe_faucet_leaks
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome, grohe faucet leaks related issues. Get free help, solutions & advice from top Grohe experts
How do you repair a leaky centerset Kohler forte fauset
That faucet has a lifetime warranty. Call Kohler (1-800-4-Kohler) and tell them you need a new cartridge for a K-10270 faucet.
Hansgrohe axor repair
follow this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals.
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 26, 2013 • Home
My rohl A3608 is leaking from the lower swivel on the faucet, how does the faucet above this swivel come off for repairing the leak?
there is a 2mm set screw on the back of the neck. Contact ROHL customer service 800.777.9762 to get replacement o-ring set to repair leak.
I have a brand new Axor Starck X 1007001 that is leaking from the bottom of the control lever. Is there an adjustment that needs to be made or is the faucet defective?
There are two possible causes for this. It could be the cartridge leaking around the top or it could have a damaged or missing o-ring between the spout and top of the faucet. Either of these could cause a leak to show only when the faucet is run. If you contact Hansgrohe Technical we can get you the parts to repair the faucet or you can send it in and we can repair it for you. 1-800-334-0455. press 2 for Tech and ask for David Scarborough. I'd be happy to help.
Apr 07, 2013 • Plumbing
2helpful
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
1helpful
Repair leaky handle
Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
Apr 21, 2009 • Plumbing
Victoria faucet Jado 51.C how to access
Here is a link to the repair parts page on Jado website for your faucet. Exploded diagram shows how the thing goes together...
http://www.jadousa.com/assets/repair/842001_repair.pdf
The handle assembly and collar (8) will thread off after pushed past the limit of the cartridge (gentle consistent pressure)...
In terms of leak itself its hard to say but if the faucet froze from sediment build up and is now leaking it is likely that part of the cartridge is 'clogged' open...
Hope that helps...
Top Delta Faucet Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Delta Faucet Hardware and Accessory Expert? Answer questions, earn points and help others
