Orion STV2763 27" TV Logo
Safro Kwame Posted on Jun 01, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wrong or 3-Digit Channel Numbers
How do I stop Orion TV Model STV2763 (27" TV) from automatically making every channel number I enter, a three-digit number; so that if I enter "6" to select channel 6 it becomes "006" or channel 006? It automatically adds two zeroes to every single number and automatically adds one zero to every two-digit number!
Anonymous
Level 3:
  • Master 883 Answers
  • Posted on Jun 01, 2007
Anonymous
Master
Level 3:
Answers
883
Questions
0
Helped
748186
Points
2537
That request is not available...firm-wared chip proprietary from orion
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
1helpful
I need a 3 digit code for RCA converter box for a Orion tv.
Hello
You haven't given a clear problem post ebefore me. You have only give the model number and brand name of your TV only. Not give the model number of your RCA converter box. Yet i posts a solution to your problem, assuming that your RCA Converter box model number is " DTA 800B1 " The three digit setup codes for Orion TV with this RCA converter box are: 029, 189, 200
ok
gopakumarg43
1helpful
Need remote code for orion tv
Hello
Three digit universal remote code for Orion are:
035/ 121/ 135
Four digit universal remote code for Orion Tv are:
0121 0135 0035
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV, with its FRONT PANEL POWER CONTROL SWITCH EACH TIME before tring an other code.
OK.
Remote codes for a universal remote
Hello
Three digit universal remote code for Orion TV are:
035/ 121/ 135
Four digit universal remote codes for Orion TV are:
0121 0135 0035
Direct Code Entry
OK.
Please tell me about orion Remote code
Hello
Three digit universal remote code for Orion are:-
035/ 121/ 135
Four digit universal remote code for Oriona are:-
0121 0135 0035
Direct Code Entry
OK.
3helpful
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Can only change the channel to single numbered channels.
Three dash option does mean it will look for three numbers. You would then have to put in three digits, so for example if you want to go to channel 31 then key in the numbers 031, for channel 42 key in 042, If you want a lower such as channel 8, then key in 008. Try this.
Akai LCT2662N Channel Changing Problem
there is a button that controls how many digits you can enter. it is located betwwn the 0 and source or below the 8 buttons
1helpful
Code
Orion Code is 035
The Instruction given is for programming a remote to control a TV set. Please substitute CABLE or VCR in place of TV to program for other devices.
1.Find the three digit code(s) for your TV set.
2. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. Try the code search method If there is no more code left to try.
7helpful
4answers
Lost code and instruction book?
Orion Codes: 035, 121, 135, 191, 394 Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.pdf Hope this helps, Good Luck :) Please Vote
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
