SOURCE: please help me bios password, which is admin system dell latitude D620
remove the laptop and, bios battery wait 10 minutes then reconnect the bios battery and repower with the power supply
SOURCE: can't remember bios admin password
I think you have just remove your motherboard battery and try to boot your pc. I hope you will be able to use your pc.
SOURCE: Need advice on how to reset admin password for
BOIS password can be done away with by removing the button cell on the motherboard for which you should remove the covers on the bottom of the laptop. Insert it after a few minutes and bootup.
SOURCE: I forgot Admin password bios
There are several follow the steep.
Download the ISO file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Write the iso in blank cd
Boot from cd
DONT PANIC follow all the steep It is very simple Use the down arrow key.
1.INSERT CD TO CD TRAY
2.Boot from CD
FOR PASSWORD BREAK
3.Select start boot CD
4.Choice Password and Registry Tools>enter
5.Choice Active password Changer for (NT/2000/XP/2003/VISTA)ADMINISTRATOR PASSWORD RESET.
If you change the HDD PASSWORD, Select ATAPWD 1.2(HDD password Utility)
wait >all will be AUTO
HERE YOU can see the option 1.Logical drive and 2.Search for all HDD and logical.
If you have one HDD choice 1. Logical drive
You you Have More then One Choice search for all hdd.
Just Choice the no and put it on the Your Choice [ ] >enter
Now Choice the partition
Either "0" or "1" which is your active partion for your Operating System. If you have two "OS" in the same HDD,
should choice all.
If you have one "OS" choice "0" to "1" press the number .Generally would be "0"
Only the reason, every laptop has the option ,for one HDD.
So Choice "0" >enter
Follow the steep on screen text > enter
From here, you can see the option for Administrator or Users .
Generally Administrator will be "0"
So pres "0">enter
Press "Y" for save changes If you want to reset the users ac password
Should press "y"
Now pres any key, and choice for Users for "1" if you want. press 1>enter
Same as y and enter .
ctrl+alt+Del
Done , you can access.
Hope it will help you.
SOURCE: I forget my Dell Vostro
Hi
Bios passwords are very difficult to bypass
you could try to remove the cmos battery and leave it out for an hour before putting it back in
sometimes this may work if you havent got a manual to show where the cmos battery is you can download one from this link www.dell.com go to support/downloads and search for the manual
also i found this link on the net you may find it interesting
httpcgi.ebay.co.ukBIOS-PASSWORD-RECOVERY-RESET-REMOVAL-PC-LAPTOP-200567780325pt=Laptops_Nov05&hash=item2eb2c573e5
if the link don't work then copy it and paste it into your search engine
also found this it makes good reading
HOW TO REMOVE THE CMOS / BIOS
PASSWORD WITHOUT DOWNLOADING Any SOFTWARE
THIS IS ONE OF
THE MECHANICAL METHODS THAT QUITE OFTEN WORKS
1 . CHEK OUT & SEE WHERE IS YOUR CMOS BATTERY LOCATED .
2 . TAKE OUT THAT CMOS BATTERY AND LEAV IT OUT FOR 30-40 MINS .
3 . NOW PLUG IT BACK IN AND RESTART HOPEFULLY IT HAS WORKED
IF THIS Did NOT WORK Try This Method
1 . THERE IS ONE JUMPER LOCATED ( near SATA hard disk slots mostly )
2 . jumper slot is of 3 pins , out of which , jumper is put into 2 pins
3 . remove the jumper & put into other 2 slots ( center one & the left or right which was not plugged into previously )
4 . start PC & u should go into bios settings without requiring the password .
5 . And there u can even change the password of bios settings .
6 . now it will ask u to put the jumper in its original position . put it there & restart
I have heard of people trying this a no of times & it seems to work
good luck
please let us know if any of these methods worked
many thanks
